dynamicMesh - move surface due to velocity/pressure |
October 27, 2014, 10:02 |
Tobias Holzmann
Rep Power: 52 |
Hi all,
I have a question and hope that someone can help me. The problem is very easy and we want to extend this to use it for our project. In the attachment there is a pipe (2d). The pipe is closed and there is a fluid inside. During cooling the density is changing and therefor the outer surface of the cylinder should move inside due to pressure force. The question at the moment:
Kind regards Tobi
Keep foaming, Tobias Holzmann |
October 27, 2014, 10:32 |
anonymous
Rep Power: 13 |
Are you meaning that the mesh should deform as an elastic problem? Or that your complete mesh should move?
October 27, 2014, 11:04 |
Tobias Holzmann
Rep Power: 52 |
Hello and thanks for your replay.
In the attachment you can find further information. Description of the PDF
Would be nice if someone can give me more information, lectures, projects etc. Kind regards Tobi
October 30, 2014, 07:23 |
anonymous
Rep Power: 13 |
Hi Tobi,
You're work is far beyond my knowledge, my only concern about this is that you should track the liquid fraction in the cells, once it reaches a desired level, you should delete it or at least modify it so that . Other problem would be that the boundary patch will change of cells. I will post this so that your thread goes to the front. |
October 30, 2014, 08:38 |
Tobias Holzmann
Rep Power: 52 |
at the moment I made a new solver which moves the mesh due to density changing. This density changes due to temperature and the mass is conserved. Everything is working fine and I will go on with 3d mesh now and then to some curved surfaces.
November 1, 2014, 15:18 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer/suggestion: http://openfoamwiki.net/index.php/Co...solidMechanics
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
Simulation of varying contact angles for a large droplet of water on a surface | cp703 | CFX | 5 | July 20, 2013 07:08 |
Comsol (4.3): convert parametric surface into block? | sgalaz | COMSOL | 0 | November 9, 2012 10:20 |
Surface Tension Test Cases | sega | OpenFOAM Running, Solving & CFD | 2 | March 8, 2011 13:19 |
swimming pool water surface motion due to wind | J.Kim | FLUENT | 4 | May 5, 2006 11:08 |
