October 27, 2014, 02:01 |
DispersionModel in sprayFoam
Fanglou
Rep Power: 11 |
Hi, everyone
I am a new foamer using OpenFoam to simulate diesel spray recently; from some paper of diesel spray submodels, I got to know turbulence dispersion is of great importance to spray development. However, why the dispersionModel is turnd off in the sprayFoam solver? And when I tried to make it like this: diespersionModel stochasticDispersionRAS Then an error appears, stochastciDispersionRAS is not a valid model?but in some other lagrangian solvers, this dispersionModel works well. could you help me about this problem,how can I use the stochasticDispersionRAS submodel? Thanks a lot! |
October 27, 2014, 16:09 |
Chris Sears
Rep Power: 11 |
I had this same issue a few weeks ago too. This is a bug that has not yet been fixed. Search the forum for how to correct this yourself & recompile, or switch to one of the alternate solvers which implement the new dispersion structure.
See but report here: http://www.openfoam.org/mantisbt/view.php?id=1259 Cheers! |
November 11, 2014, 21:16 |
Fanglou
Rep Power: 11 |
thanks a lot for you kind help!really sorry for the quite late reply! I have solved this problem, it is just because the wrong installation. as suggested by one of my friends, I reinstalled OpenFoam-2.3.x,then it works! so I think you can also try it!
good luck! |
Bubble column with sprayFoam | dav.dap83 | OpenFOAM Running, Solving & CFD | 18 | November 30, 2020 14:06 |
Incorrect introduced mass in sprayFoam? | sushant | OpenFOAM Running, Solving & CFD | 25 | July 10, 2020 00:39 |
Fluctuating Liquid Penetration for Wedge sprayFoam | ahcai007 | OpenFOAM Running, Solving & CFD | 15 | March 22, 2018 02:53 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 09:29 |
sprayFoam crashes | lukasfischer | OpenFOAM Running, Solving & CFD | 3 | July 14, 2013 11:08 |
