SimpleFoam high time-step continuity error on a simple geometry |
December 23, 2020, 08:34 |
a few suggestions
#41 |
Ahmet Can Ilhan
The problem with time continuity error rising may not always caused by BCs or relaxations. In my some cases I solved this error with refine the mesh. I highly reccomend checkMesh utility for all mesh generations. If there is for example non-orthagonality error that you were thinking its negligible, it can occur some time continuity errors. And this suggestion went us to snappyHexMesh. I always thought If I want to solve the non-orthagonality or skewness errors, must play with snappyHexMesh settings. But the truth is this delays me to solve my problem every time.
The secret is completing this job in blockMeshDict. If you have a background mesh, refine it with multiplying 8 or higher depending upon your computer capabilities. And run snappy after this refinement. Snappy works very well with that way. And how much your mesh quality is good, your solution will be perfect. I mean very low residuals and stable time continuities. |
Rapidly decreasing deltaT for interDyMFoam | chrisb2244 | OpenFOAM Running, Solving & CFD | 3 | July 1, 2014 17:40 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 03:34 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
