SimpleFoam high time-step continuity error on a simple geometry
Like Tree4Likes
Old   October 29, 2014, 11:39
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Originally Posted by Chrisstiapis View Post
A problem that I was facing was that although i know the pressure on the outlet cannot use it cause whenever I was putting fixed value or total pressure the solution was becoming divergent
I am sorry, I don't understand this. Could You try other words? Your b.c.s look fine, are all four outlets merged to one outlet called "outlet_extruded"?
This procedure with the map-fields looks promising although i have never used this function before.
If you create the first (cyclic) case, create it in a way that it's outlet already lies at exactly the same position as the inlet of your current (second) case, same coordinates and same direction. Just as in the picture of the thread I linked above. This works... If you have problems, just write me.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   October 29, 2014, 11:45
Chris Stiapis
Chrisstiapis is on a distinguished road
In my case the velocity and the pressure at the inlet are both known. (feed is a pump fixed flowrate and pressure)
The problem that when I'm defining the pressure on the inlet my solutions explodes, some insane velocities pop out of the blue.
That's why I have put zerogradient on the inlet.
I think by doing so, the solution is stable but I'm loosing important information.
#As fas as I'm aware in Navier-Stokes equations the pressure gradient drives the flow.#
I tried many combinations of boundary conditions but none of them converges.
Chrisstiapis is offline   Reply With Quote
Old   October 29, 2014, 11:53
Philipp
Ok, I don't think you can set pressure value at inlet and outlet and velocity at the inlet at once. This will end up in over determination.
For incompressible flow, You can
1) set inlet pressure and outlet pressure, velocity gradient at inlet and outlet. This will define the amount of flow through your system by the pressure difference. You can not additionally set the velocity.
2) set outlet (or inlet) pressure and velocity inlet, but with zero gradient for pressure at the other side.
For me case "2" is standard.
Edit: I think I did not understand you correctly. Now: Setting velocity and pressure value at inlet and both zero gradient at outlet should work... I think.
Old   October 30, 2014, 05:10
Chris Stiapis
Dear Rodriguez,
The simulation managed to converged after 25000 iterations.
The total cummulative error reduced to 10^-9. So for my case at least for now the problem is solved.
Now, I tried just becasuse I'm curious to see what will hapen if i define the pressureand the velocity at the inlet.
As u said it shouldn't be any issues, but I get this error message
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
 at ??:?
 at ??:?
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
 at ??:?
Floating point exception (core dumped)
Weird and Wicked
Old   October 30, 2014, 05:12
Philipp
Hmm... I don't understand this. For incompressible flow, the absolute pressure value doesn't mean anything, so it should be completely unimportant where in the domain the pressure is "hard-wired". Can you upload the whole case?
Old   October 30, 2014, 05:14
Philipp
Anyway: the four outlets are all outlets to the ambient pressure? Is that correct?
Old   October 30, 2014, 05:46
Chris Stiapis
The outlets are placed at the bottom of a vessel. The pressure on the outlets in pout=rho*g*h=995*9.81*4.5----> the height of the water level.
I think in this cases the pressure on the outlet and is equal to the hydrostatic pressure.
Old   October 30, 2014, 05:50
Philipp
That means, that the pressure at the four outlets is imposed by the ambience, i.e. the height of the water and not by the air flow of your simulation domain? So from the CFD point of view it is a boundary condition? Is that right?
Old   October 30, 2014, 05:56
Chris Stiapis
It's true.
I cannot upload the case, there is a limitation on the MB that someone can upload.
http://www.filedropper.com/wholecase
Old   October 30, 2014, 06:00
Philipp
Chris, this doesn't work as you think. If you have a fixed outlet pressure as in your case, you can not fix the inlet flow and inlet pressure by a pump. This is not possible. You can either fix the flow and some pressure drop over your domain will develop, or you can fix the pressure drop and some mass-flow will develop. Both doesn't work. This is true for both the experiment and the simulation.
I will have a look at your case anyway.
You are fine. See this post: http://www.cfd-online.com/Forums/ope...tml#post201915
Old   October 30, 2014, 06:38
Chris Stiapis
Rodriguez, what do you think about the boundary conditions ???
Cause the last thing you told me made me worried.
Are u aware of any similar case ???
Old   October 30, 2014, 06:45
anonymous
ssss is on a distinguished road
Are you using nonOrthogonalCorrectors?
Could you try fixing velocity in outlet and fixing pressure in inlet? Just the opposed as what you are doing. I think there is a problem with your boundary conditions.
ssss is offline   Reply With Quote
Old   October 30, 2014, 07:17
Chris Stiapis
SSS, No I'm not using non orthogonal correctors, cause mesh non orthogonality is below 60.
I did as u suggested and i get this error message
#3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:?
#6  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#7  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#9  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
Old   October 30, 2014, 07:32
Philipp
Chris, your boundary conditions are fine. Just at the outlet for pressure you try to set two different conditions: fixed value and zero gradient. Just delete the line with "zero gradient".
Also, set relTol for all solvers to "0.1"
I recommend to set outlet pressure to zero, because you will be able to see much more in the pictures after the simulation has run. Just bear in mind that this doesn't change the result at all, except that your absolute pressure value changes. Not the relative pressure (i.e. difference) between inlet and outlet.
When you get that error message, do you try to set inlet and outlet pressure? This doesn't work in combination with setting inlet velocity, as I tryed to explain.
Old   October 30, 2014, 07:40
anonymous
I downloaded your testcase and modified the following, for me it's running now:
First of all I added a ";" in the p boundary field, next time try to upload something that works
After that I went to fvSolution and then to SIMPLE dictionary:
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       49000;
    residualControl
        p               1e-8;
        U               8e-8;
        "(k|epsilon|omega)" 1e-8;
simpleFoam asked me to set the pression ref value. You could set your internal pressure to 0 in your boundaryField because you're running an incompressible case because pressure has nothing to do with density thus you're only taking into account pressure variations not absolute values.
I'm using OF230.
Old   October 30, 2014, 07:43
Philipp
Originally Posted by ssss View Post
You need to set the pression ref value.
I agree with the other things you wrote, but if he sets the absolute pressure value at the outlet (what he did), this is not necessary. Only if he sets both inlet and outlet pressure to zero gradient.
ssss likes this.
Old   October 30, 2014, 07:48
anonymous
Dear RodriguezFatz,
I didn't know that Openfoam could handle that situacion without setting pRefCell, as I always used 0 anyway. But simpleFoam asked me to write in the fvSolution so I just wrote it and it worked.
I will correct my post.
Thank you very much
Old   October 30, 2014, 07:55
Philipp
It can handle it, because by setting the outlet to some fixed value, you already have an absolute reference pressure inside your domain. It just won't use the pRef value in that case.
ssss likes this.
Old   May 10, 2016, 06:32
gned
gned is on a distinguished road
So Chris,
how did you solve your continuity errors on the pipe system ? Which are your suggestions for similar cases?
In your last post you sent your last bcs on U and p but than said, on the contrary, you had to avoid the fixed pressure value at the outlets. So with which bcs you could solve the simulation and with which final fvSchemes of the many suggested? Are the pressures equal for all the outlets ? Your outlet discharge vessel was not pressurized ? Did you measure experimentally these pressures at the outlets to be sure?
gned is offline   Reply With Quote
Old   May 12, 2016, 06:26
gned
Hi ssss,
just a question about this old post #32 by you about settling the right bcs. I have to solve something similar to Chris problem. Unfortunately, contrary to him, I don't trust too much the experimental measures they gave to me, in particular about the p at the outlet. Usually, for the bcs classically on this kind of problems are used :
inlet:
p ---> zeroGradient
U ---> flowRateInletVelocity
outlets :
p ----> fixedValue
U ----> zeroGradient
At the inlet, on the contrary, that is at the pump side my confidence on the the right values of p is more.So in your opinion, since I have big problems to get convergence as Chris had, can be the same if I try the other way :
inlet :
p ----> fixedValue
outlets :
p ---> zeroGradient
(about this latter, since personally i have only one inlet but 4 different outlets, it's sufficient that I rename with createPatchDict all the outlets under the same boundary patch name and then the flowRate condition is managed right by the solver among the 4 outlets ?)
These conditions I think are numerically wellposed, am I right ?
Why do you think in such problems (flows through orifices/pipes restrictions) we have so many difficulties to converge in OF in general (I found many other people to complain about similar cases issues in the forum indeed)?
thanks a lot
Rapidly decreasing deltaT for interDyMFoam chrisb2244 OpenFOAM Running, Solving & CFD 3 July 1, 2014 17:40
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
