twoPhaseEulerFoam-2.3.x breaks my bubble column |
January 19, 2015, 05:05 |
#21 |
Samuele Z
Rep Power: 19 |
Dear All,
I am pretty new with the multi-phase modeling. I am going to simulate a bubble-column, in order to investigate, but I can not understand very well all the settings. Is there a good tutorial to start from, according to you? Thanks a lot, Samuele |
June 21, 2015, 07:42 |
fuctuations in bubbe pume
#22 | |
Fatema Zandi Goharrizi
Rep Power: 17 |
Is fluctuations in plume of bubble in this solver due to drag model? Schiller-Naumann can do fix it? in water and air mixing flow. Really Thank you Fatema |
August 11, 2015, 05:43 |
#23 |
Mohsen
Rep Power: 14 |
Hi everybody,
I want to simulate a bubble column. In this case, the gas phase is absorbed by the liquid phase and there is a reaction in the liquid phase. I'm going to use OpenFOAM. I want to combine twoPhaseEulerFoam and reactingFoam. Could you tell me your idea about this case? Do you have any suggestion for me? what is the term of + fvOptions(rho, Yi) in the YEqn.H of reactingFoam? Looking forward to your answers. Thanks in advance. |
August 11, 2015, 06:38 |
#24 |
Rep Power: 17 |
September 8, 2015, 06:07 |
bubble column reactor
#25 |
surya
Rep Power: 11 |
can any one help to simulate my bubble column which is having co-current flow of air and water. Is it possible to provide boundary conditions for inlet air and water or is it necessary to define a stagnant liquid column?
September 8, 2015, 07:25 |
#26 | |
Rep Power: 17 |
yes it is. I don't know alot about "co-current flow of air and water" but you can with different U files for water and air . |
September 8, 2015, 07:29 |
#27 | |
Mohsen
Rep Power: 14 |
You can use bubbleColumn case in OpenFOAM tutorial and you should only add inlet and outlet for liquid phase, OpenFOAM solves momentum equation for liquid phase and so, there isn't any limitation for liquid flow. bests. |
September 9, 2015, 01:25 |
#28 | ||
surya
Rep Power: 11 |
I am trying to do in fluent.. If you have similar tutorials can you please upload.. -------------- Quote:
i am sorry i didnt understand what is this U files? Last edited by wyldckat; September 9, 2015 at 16:38. Reason: merged posts that were a few minutes apart |
October 21, 2015, 10:29 |
#29 |
Mohsen
Rep Power: 14 |
Hi friends,
Could you please take a look on my post in this link: http://www.cfd-online.com/Forums/ope...tml#post567674 Is it possible to add mass transfer equation to twoPhaseEulerFoam solver according to my problem? Do you have any better Idea for me? Any suggestion will be kind of you. Best Regards Mohsen |
October 26, 2015, 03:28 |
#30 | |
Alberto Passalacqua
Rep Power: 36 |
Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
October 26, 2015, 11:09 |
#31 |
Mattia de\' Michieli Vitturi
Rep Power: 17 |
Hi Alberto,
looking at reactingTwoPhaseEulerFoam I have not found in the alpha equation any term accounting for mass transfer. I only had quick look so I may be wrong, also because there are a lot of changes in the solvers structure from OpenFoam 2.4.0. Is this correct? Thank you Mattia |
October 26, 2015, 14:25 |
#32 | |
Mohsen
Rep Power: 14 |
Thank you very much for your reply. I'll try it. Best Regards |
January 5, 2016, 04:06 |
#33 |
Rep Power: 17 |
May 30, 2016, 10:41 |
#34 |
Rep Power: 11 |
Hi
I want to simulate bubbly flow. I want to use twophaseEulerfoam or reactingtwophaseEulerfoam. which one I use for simulate? and what is the different between them? THANKS |
December 12, 2017, 07:08 |
#35 | |
Andrea Ferrari
Rep Power: 17 |
Hello, i am trying to understand how blending is handled in twoPhaseEulerFoam (v1706). For what i understood by reading the source code we have 3 cases: 1) alpha <= maxFullyDispersedAlpha.phase1. The drag model for phase1 dispersed in phase2 is used (K1in2). 2) alpha > maxFullyDispersedAlpha.phase2. The drag model for phase2 dispersed in phase1 is used (K2in1). 3) maxPartlyDispersedAlpha.phase1 =< alpha <= maxPartlyDispersedAlpha.phase2. A linear combination of the 2 drag models is used. Something like K() = f1*K1in2 + f2*K2in1 Is this correct? And if I specified a segregated drag model to handle cases when none of the phase is truly dispersed, where does it come into play? When maxPartlyDispersedAlpha.phase1 < alpha < maxPartlyDispersedAlpha.phase2 is the segregated drag model used, instead of the linear combination? ps i edited since maxFullyDispersedAlpha and maxPartlyDispersedAlpha are defined for both phases. Thanks, Andrea Last edited by Andrea_85; December 12, 2017 at 08:45. |
openfoam-2.3, openfoam-2.3.x, twophaseeulerfoam |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 20, 2014 00:42 |
twoPhaseEulerFoam Simulations of bubble column | vishal3 | OpenFOAM | 1 | July 7, 2014 05:12 |
becker bubble column with twoPhaseEulerFoam | GerhardHolzinger | OpenFOAM Running, Solving & CFD | 4 | November 25, 2013 02:53 |
Solving bubble column using twoPhaseEulerFoam | vishal3 | OpenFOAM Pre-Processing | 0 | July 11, 2013 07:19 |
twoPhaseEulerFoam : bubble column modeling | chittipo | OpenFOAM Running, Solving & CFD | 2 | June 11, 2012 07:12 |
