Unbounding alpha in Dambreak case
Old   October 23, 2014, 03:51
Default Unbounding alpha in Dambreak case
Dongyue Li
sharonyue is on a distinguished road
Hi guys!
In the original dambreak case, alpha's outlet boundary is set as:
atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
I think that means water and air can get out but only air can get in. Then I revise it into:
atmosphere
        type            outletInlet;
        outletValue      uniform 0;
        value           uniform 0;
and make there is more water in the fields by :
defaultFieldValues
    volScalarFieldValue alpha.water 0
regions
    boxToCell
        box (0 0 -1) (0.3 0.5 1);
        fieldValues
            volScalarFieldValue alpha.water 1
Then I run interFoam in OpenFOAM 2.2.x and 2.3.0. I can see that alpha is unbounded:
2.3.0
Courant Number mean: 0.032188 max: 0.996634
Interface Courant Number mean: 0.000976763 max: 0.220003
deltaT = 7.3338e-05
Time = 0.886652
smoothSolver:  Solving for alpha.water, Initial residual = 0.0004712, Final residual = 4.5912e-09, No Iterations 1
Phase-1 volume fraction = 0.459894  Min(alpha1) = -3.87751e-11  Max(alpha1) = 143.031
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.459894  Min(alpha1) = -8.17479e-08  Max(alpha1) = 142.755
DICPCG:  Solving for p_rgh, Initial residual = 0.000217595, Final residual = 7.50267e-06, No Iterations 2
time step continuity errors : sum local = 1.21984e-07, global = 6.70143e-09, cumulative = -0.000355408
DICPCG:  Solving for p_rgh, Initial residual = 1.75272e-05, Final residual = 8.56153e-07, No Iterations 5
time step continuity errors : sum local = 1.39203e-08, global = -6.03115e-10, cumulative = -0.000355409
DICPCG:  Solving for p_rgh, Initial residual = 5.98614e-06, Final residual = 9.99259e-08, No Iterations 22
time step continuity errors : sum local = 1.6247e-09, global = -1.64737e-10, cumulative = -0.000355409
ExecutionTime = 63.87 s  ClockTime = 64 s
2.2.x is the same.
So we can see that when the water is getting out, alpha tends to be unbounded.
My aim is keep water in this field so I modify alpha's boundary. So what should I do?
Thanks in advance
sharonyue is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Significance of Alpha and Solvers Application jolync OpenFOAM 2 January 31, 2011 15:40
Runing InterFoam for 3 D damBreak case Patch issue nishant_hull OpenFOAM Running, Solving & CFD 5 February 18, 2009 01:32
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
