Compressor Simulation using rhoPimpleDyMFoam
Like Tree11Likes
Old   October 22, 2014, 07:25
Default Compressor Simulation using rhoPimpleDyMFoam
Abhijit
Jetfire is on a distinguished road
Hi
I am simulating compressor stage of a turbocharger with the rhoPimpleDyMFoam solver. running moveDynamicMesh -checkAMI was smooth without any errors which assures that my mesh rotates properly and i have defined my interfaces correctly , please point out if i am assuming this wrong.
However running the solver my simulation crashes showing this
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.0-f5222ca19ce6
Exec   : rhoPimpleDyMFoam
Date   : Oct 22 2014
Time   : 15:58:22
Host   : "EAT-Standalone"
PID    : 4587
Case   : /home/eatin/OpenFOAM/eatin-2.3.0/run/tutorials/TurboCharger/Trial_4
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone FLUID_ROTOR
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
AMI: Creating addressing and weights between 1900 source faces and 32076 target faces
AMI: Patch source sum(weights) min/max/average = 0.995594, 1, 0.999764
AMI: Patch target sum(weights) min/max/average = 0.432794, 1, 0.996788
AMI: Creating addressing and weights between 17748 source faces and 5456 target faces
AMI: Patch source sum(weights) min/max/average = 0.435302, 1.03344, 1.00009
AMI: Patch target sum(weights) min/max/average = 0.816766, 1.00271, 0.999924
AMI: Creating addressing and weights between 17839 source faces and 1957 target faces
AMI: Patch source sum(weights) min/max/average = 0.86998, 1, 0.999108
AMI: Patch target sum(weights) min/max/average = 0.991279, 1, 0.99992
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
#0  Foam::error::printStack(Foam::Ostream&) in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::compressible::mutkWallFunctionFvPatchScalarField::calcMut() const in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#4  Foam::compressible::mutWallFunctionFvPatchScalarField::updateCoeffs() in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#5  Foam::fvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/rhoPimpleDyMFoam"
#6  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/rhoPimpleDyMFoam"
#7  Foam::compressible::RASModels::kEpsilon::kEpsilon(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#8  Foam::compressible::RASModel::adddictionaryConstructorToTable<Foam::compressible::RASModels::kEpsilon>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#9  Foam::compressible::RASModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#10  Foam::compressible::turbulenceModel::addturbulenceModelConstructorToTable<Foam::compressible::RASModel>::NewturbulenceModel(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#11  Foam::compressible::turbulenceModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/home/eatin/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#12
#13  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14
Floating point exception (core dumped)
I am not able to identify what exactly is the problem and i suppose this is not due to the AMI interfaces as moveDynamicMesh was running perfectly. I have understood after reading few threads that it might be related to my boundary conditions, fvSchemes or fvSolution but i have no idea how to correct this. Please help me solve this and let me know if you need anymore details regarding my simulation.
Thanks
Jetfire is offline   Reply With Quote
Old   October 22, 2014, 07:35
Abhijit
Coming to my simulation i have to simulate compressor stage of a turbocharger
Meshing was done using ANSYS ICEM CFD , i had 3 mesh files
1. Inlet&Outlet
2.Volute
3.Rotor
I imported them to openfoam using fluent3DMeshToFoam and then used mergeMeshes to make the complete domain, after that used
splitMeshRegions -makeCellZones -overwrite to distinguish between the rotating zone and stationary zone.
I am attaching few pictures of the domain so you could get a clear picture.Please have a look at them
Old   October 22, 2014, 07:38
Abhijit
This is the complete domain of my simulation
File Type: jpg Screenshot from 2014-10-22 15:50:27.jpg (39.2 KB, 179 views)
Old   October 22, 2014, 08:39
Paritosh Vasava
vasava will become famous soon enough
1. How are you merging your three meshes that you have imported from fluent?
2. How did you create AMI patches?
3. Do you have 'sets' folder (with several domains) inside the constant folder?
vasava is offline   Reply With Quote
Old   October 23, 2014, 04:36
Abhijit
@vasava
As i have 3 mesh files
1.I created 3 case folders 1.Rotor 2.Volute 3.Inlet_Outlet
2. Placed the 3 mesh files into corresponding case folders and used fluent3DMeshToFoam fluent.msh -scale 0.001 for each to convert to meters
3.merged Rotor and volute , and then merged the combined mesh with Inlet_Outlet
4.used splitMeshRegions -makeCellZones -overwrite to create cell zones of different regions , 3 in my case
To create the AMI patches i used the createPatchDict, I will attach it for your reference
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync false;
// Patches to create.
patches
        //- Master side patch
        name            AMI1;
        patchInfo
            type            cyclicAMI;
            matchTolerance  0.0001;
            neighbourPatch  AMI2;
            transform       noOrdering;
        constructFrom patches;
        patches (INT_STA_ROT_master);
        //- Slave side patch
        name            AMI2;
        patchInfo
            type            cyclicAMI;
            neighbourPatch  AMI1;
        patches (INT_STA_ROT_slave);
        name            AMI3;
        patchInfo
            type            cyclicAMI;
            neighbourPatch  AMI4;
        patches (INT_ROT_STA_master);
        name            AMI4;
        patchInfo
            type            cyclicAMI;
            neighbourPatch  AMI3;
        patches (INT_ROT_STA_slave);
        name            AMI5;
        patchInfo
            type            cyclicAMI;
            neighbourPatch  AMI6;
        patches (INT_OUTLET_HOUSING_master);
        name            AMI6;
        patchInfo
            type            cyclicAMI;
            neighbourPatch  AMI5;
        patches (INT_OUTLET_HOUSING_slave);
Yes, i have sets in my constant folder with different domains
Old   October 23, 2014, 06:50
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Your problem seems to be in the turbulence model, I am guessing you have put epsilon equal to zero somewhere in either a boundary patch or the internalField. Change this to a sensible value for your case.
Regards,
Tom
tomf is offline   Reply With Quote
Old   October 23, 2014, 10:01
Paritosh Vasava
Your mesh setup seems alright. I agree with tomf, get some appropriate values for turbulence and use them in initial condition.
Also can you post your boundary file here?
Old   October 27, 2014, 02:04
Abhijit
Hi ,
Sorry for the late reply and thanks for your response
I have checked my epsilon file and have not put zero anywhere and ya as you have suggested i am working on my initial and boundary conditions as this might be the source of error.
@vasava
Here is my boundary file
FoamFile
    version     2.0;
    format      binary;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
16
    WALL_HUB
        type            wall;
        inGroups        1(wall);
        nFaces          32413;
        startFace       16826280;
    WALL_BACK_PLATE_ROT
        type            wall;
        inGroups        1(wall);
        nFaces          14330;
        startFace       16858693;
    WALL_SHOURD
        type            wall;
        inGroups        1(wall);
        nFaces          36540;
        startFace       16873023;
    WALL_BLADE
        type            wall;
        inGroups        1(wall);
        nFaces          96768;
        startFace       16909563;
    WALL_HOUSING
        type            wall;
        inGroups        1(wall);
        nFaces          265149;
        startFace       17006331;
    WALL_BACK_PLATE_STA
        type            wall;
        inGroups        1(wall);
        nFaces          39172;
        startFace       17271480;
    WALL_FREESLIP_INLET
        type            wall;
        inGroups        1(wall);
        nFaces          6004;
        startFace       17310652;
    WALL_FREESLIP_OUTLET
        type            wall;
        inGroups        1(wall);
        nFaces          17404;
        startFace       17316656;
    OUTLET
        type            patch;
        nFaces          1957;
        startFace       17334060;
    INLET
        type            patch;
        nFaces          2945;
        startFace       17336017;
    AMI1
        type            cyclicAMI;
        inGroups        1(cyclicAMI);
        nFaces          1900;
        startFace       17338962;
    AMI2
        type            cyclicAMI;
        nFaces          32076;
        startFace       17340862;
    AMI3
        type            cyclicAMI;
        nFaces          17748;
        startFace       17372938;
    AMI4
        type            cyclicAMI;
        nFaces          5456;
        startFace       17390686;
    AMI5
        type            cyclicAMI;
        nFaces          17839;
        startFace       17396142;
    AMI6
        type            cyclicAMI;
        nFaces          1957;
        startFace       17413981;
One question , I have many boundaries i.e 16 in my boundary file. Is it necessary to define initial and boundary conditions for all these in my 0 folder?
Old   October 27, 2014, 02:20
Paritosh Vasava
Originally Posted by Jetfire View Post
Hi ,
Yes you have to else openFoam will complain even before your calculation starts.
The boundary file looks ok but did you try any other turbulence setup??
Old   October 27, 2014, 02:30
Abhijit
Hi vasava,
Do you mean any of these two? I started with K-Epsilon as it was the basic turbulence model to start with.
1.K-omega SST
2.Spalart-Allmaras
I am attaching my 0 folder , please take a look at my initial and boundary conditions and help me correct them. I have copied and modified the files from annularThermalMixer tutorial.
Old   October 27, 2014, 05:16
Tom Fahner
You have provided a relative pressure of 0 Pa, you should put the absolute pressure. OpenFOAM does not use a "gauge pressure" or similar for compressible solvers. The solver now tried to solve for an absolute vacuum, which it could not do. I guess it only found out when density was required to calculated some part of the turbulence model.
For incompressible cases 0 m2/s2 is allowed since in that case the absolute pressure does not matter.
Regards,
Tom
Jetfire likes this.
Old   October 27, 2014, 06:02
Abhijit
Regards,
Tom
Hi tomf,
I changed the pressure file as suggested by you creating a pressure difference between inlet and outlet but i still end up getting the same error .
Alexeym has suggested this might be the cause of my error:
as you've got FPE in mutkWallFunctionFvPatchScalarField::calcMut(), look at the source of the wall function:
tmp<scalarField> mutkWallFunctionFvPatchScalarField::calcMut() const
    const label patchi = patch().index();
    const turbulenceModel& turbModel =
        db().lookupObject<turbulenceModel>("turbulenceModel");
    const scalarField& y = turbModel.y()[patchi];
    const scalarField& rhow = turbModel.rho().boundaryField()[patchi];
    const tmp<volScalarField> tk = turbModel.k();
    const volScalarField& k = tk();
    const scalarField& muw = turbModel.mu().boundaryField()[patchi];
    const scalar Cmu25 = pow025(Cmu_);
    tmp<scalarField> tmutw(new scalarField(patch().size(), 0.0));
    scalarField& mutw = tmutw();
    forAll(mutw, faceI)
        label faceCellI = patch().faceCells()[faceI];
        scalar yPlus =
            Cmu25*y[faceI]*sqrt(k[faceCellI])/(muw[faceI]/rhow[faceI]);
        if (yPlus > yPlusLam_)
            mutw[faceI] = muw[faceI]*(yPlus*kappa_/log(E_*yPlus) - 1);
    return tmutw;
There's several possible reasons for FPE:
1. rhow[faceI] == 0
2. muw[faceI] == 0
3. k[faceCellI] < 0
4. E_*yPlus <= 0 (this is not the case, cause yPlus > yPlusLam_)
So you need to check if any of conditions 1-3 is true in your case.
I am able to figure out that these conditions come from the equations to have a proper solution but unable to understand which values i should correct.Please explain me if you can interpret what the problem exactly is.
Thanks
Old   October 27, 2014, 06:09
Tom Fahner
Could you just show the p file, I was not talking about a pressure difference between inlet and outlet, I meant that you cannot have 0 Pa anywhere in the domain (internalField or any boundary condition), it should be around your absolute operating pressure (101325 Pa for standard atmosphere conditions).
I guess it should look something like this:
FoamFile
    version     2.0;
    format      binary;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
    WALL_HUB
        type            zeroGradient;
    OUTLET
        type            fixedValue;
        value           uniform 101325;
    INLET
        type            zeroGradient;
    WALL_BACK_PLATE_ROT
        type            zeroGradient;
    WALL_SHOURD
        type            zeroGradient;
    WALL_BACK_PLATE_STA
        type            zeroGradient;
    WALL_BLADE
        type            zeroGradient;
    WALL_HOUSING
        type            zeroGradient;
    WALL_FREESLIP_INLET
        type            zeroGradient;
        type            zeroGradient;
    AMI1
        type            cyclicAMI;
    AMI2
        type            cyclicAMI;
    AMI3
        type            cyclicAMI;
    AMI4
        type            cyclicAMI;
    AMI5
        type            cyclicAMI;
    AMI6
        type            cyclicAMI;
Regards,
Tom
Old   October 27, 2014, 06:31
Abhijit
@tomf,
Thank you very much.
Just changed my p-file as suggested by you, now my simulation started running!!
I was always worried about the mut-file , dint expect the error was in my p-file.
For now the simulation is running but too slow,have to run it in parallel and maybe some changes in my fvSchemes and fvSolution will do. il come back to you in case of any queries, thanks a lot!
Old   November 6, 2014, 04:02
Question
  #15
Abhijit
Hi ,
I am simulating compressor of a turbocharger using rhoPimpleDyMFoam with kOmegaSST turbulence model.
Boundary conditons are as follows:
mass flow outlet : 0.04 kg/s
total pressure inlet:101325
total temperature inlet:298k
compressor rpm: 300,000
Can you help me with my FvSchemes and FvSolutions as to what modifications i should be doing for better results. let me know if you need any more details about the simulation.
FvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,h)      Gauss linearUpwind grad(h);
    div(phi,K)      Gauss linear;
    div(meshPhi,p)  Gauss linear;
    div(phi,k)      Gauss upwind;
    div(phi,omega) Gauss upwind;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
    pcorr           ;
FvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver           GAMG;
        smoother         GaussSeidel;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels      1;
        tolerance       1e-6;
        relTol          0.01;
    pFinal
        $p;
        relTol          0;
    pcorr
        $p;
        tolerance       1e-2;
        relTol          0;
    "(rho|U|h|k|epsilon|omega)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-06;
        relTol          0.1;
    "(rho|U|h|k|epsilon|omega)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor   yes;
    transonic           no;
    nOuterCorrectors    1;
    nCorrectors         3;
    nNonOrthogonalCorrectors 1;
    rhoMin          rhoMin [ 1 -3 0 0 0 ] 0.5;
    rhoMax          rhoMax [ 1 -3 0 0 0 ] 2.0;
relaxationFactors
    fields
    equations
        "(U|h|k|epsilon|omega).*" 1;
Thanks
Old   November 6, 2014, 10:24
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Whats the matter with your current results? Any problems?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 7, 2014, 00:00
Abhijit
Hi RodriguezFatz,
I have started running the simulation and each timestep is taking a lot of time. Is there anything to do with my FvSolution or FvSchemes files to speed up my simulation? I am already running it on 8 cores.
Old   November 7, 2014, 03:26
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
So at least there is no problem ...
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   November 7, 2014, 03:33
Abhijit
Hi tobi,
My simulation has been running from past 1 day and still going on
Here is the output
Courant Number mean: 0.000114809 max: 1
deltaT = 1.41799e-09
Time = 5.81839e-07
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 5.81839e-07 transformation: ((0 0 0) (0.999958 (0.00913938 0 0)))
AMI: Patch source sum(weights) min/max/average = 0.99546, 1, 0.999763
AMI: Patch target sum(weights) min/max/average = 0.467982, 1, 0.996805
AMI: Patch source sum(weights) min/max/average = 0.538509, 1.06046, 1.00015
AMI: Patch target sum(weights) min/max/average = 0.685009, 1.00305, 0.999864
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.00998453, No Iterations 47
GAMG:  Solving for pcorr, Initial residual = 0.0244185, Final residual = 0.00465247, No Iterations 1
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
rhoEqn max/min : 2.15688 0.182153
smoothSolver:  Solving for Ux, Initial residual = 3.26172e-05, Final residual = 2.14196e-09, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.00157835, Final residual = 1.29594e-07, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.00176688, Final residual = 1.35932e-07, No Iterations 1
smoothSolver:  Solving for h, Initial residual = 0.000933756, Final residual = 7.49315e-08, No Iterations 1
GAMG:  Solving for p, Initial residual = 7.71888e-05, Final residual = 3.25475e-13, No Iterations 1
GAMG:  Solving for p, Initial residual = 1.49854e-09, Final residual = 1.49854e-09, No Iterations 0
time step continuity errors : sum local = 0.00014808, global = -0.000129601, cumulative = -0.0697627
rho max/min : 2 0.5
GAMG:  Solving for p, Initial residual = 1.52653e-07, Final residual = 1.52653e-07, No Iterations 0
time step continuity errors : sum local = 0.000148089, global = -0.000129601, cumulative = -0.0698923
rho max/min : 2 0.5
GAMG:  Solving for p, Initial residual = 1.52573e-07, Final residual = 1.52573e-07, No Iterations 0
time step continuity errors : sum local = 0.000148089, global = -0.000129601, cumulative = -0.0700219
rho max/min : 2 0.5
smoothSolver:  Solving for omega, Initial residual = 2.31798e-06, Final residual = 1.30867e-10, No Iterations 1
bounding omega, min: -6301.47 max: 5.70133e+09 average: 2.17771e+06
smoothSolver:  Solving for k, Initial residual = 2.69839e-05, Final residual = 1.04992e-09, No Iterations 1
ExecutionTime = 62085.4 s  ClockTime = 83417 s
Courant Number mean: 0.000114789 max: 1
Time = 5.83257e-07
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 5.83257e-07 transformation: ((0 0 0) (0.999958 (0.00916165 0 0)))
AMI: Patch source sum(weights) min/max/average = 0.995459, 1, 0.999763
AMI: Patch target sum(weights) min/max/average = 0.468157, 1, 0.996805
AMI: Patch source sum(weights) min/max/average = 0.537877, 1.06201, 1.00015
AMI: Patch target sum(weights) min/max/average = 0.681757, 1.00303, 0.999863
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.00918253, No Iterations 49
GAMG:  Solving for pcorr, Initial residual = 0.0244148, Final residual = 0.00465114, No Iterations 1
rhoEqn max/min : 2.15666 0.1872
smoothSolver:  Solving for Ux, Initial residual = 3.25967e-05, Final residual = 2.1407e-09, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.00157519, Final residual = 1.29333e-07, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.00176436, Final residual = 1.35799e-07, No Iterations 1
smoothSolver:  Solving for h, Initial residual = 0.000915801, Final residual = 7.35108e-08, No Iterations 1
GAMG:  Solving for p, Initial residual = 7.69707e-05, Final residual = 3.22893e-13, No Iterations 1
GAMG:  Solving for p, Initial residual = 1.49221e-09, Final residual = 1.49221e-09, No Iterations 0
time step continuity errors : sum local = 0.000148538, global = -0.000130024, cumulative = -0.0701519
rho max/min : 2 0.5
GAMG:  Solving for p, Initial residual = 1.51827e-07, Final residual = 1.51827e-07, No Iterations 0
time step continuity errors : sum local = 0.000148547, global = -0.000130024, cumulative = -0.0702819
rho max/min : 2 0.5
GAMG:  Solving for p, Initial residual = 1.51748e-07, Final residual = 1.51748e-07, No Iterations 0
time step continuity errors : sum local = 0.000148547, global = -0.000130024, cumulative = -0.0704119
rho max/min : 2 0.5
smoothSolver:  Solving for omega, Initial residual = 2.31335e-06, Final residual = 1.3162e-10, No Iterations 1
bounding omega, min: -3196.96 max: 5.70337e+09 average: 2.17777e+06
smoothSolver:  Solving for k, Initial residual = 2.69244e-05, Final residual = 1.05185e-09, No Iterations 1
ExecutionTime = 62226.4 s  ClockTime = 83606 s
Courant Number mean: 0.000114768 max: 1
deltaT = 1.41798e-09
Time = 5.84675e-07
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 5.84675e-07 transformation: ((0 0 0) (0.999958 (0.00918393 0 0)))
AMI: Patch source sum(weights) min/max/average = 0.995457, 1, 0.999763
AMI: Patch target sum(weights) min/max/average = 0.468334, 1, 0.996805
AMI: Patch source sum(weights) min/max/average = 0.537262, 1.06316, 1.00015
AMI: Patch target sum(weights) min/max/average = 0.678559, 1.00301, 0.999883
Do i need to change solver for pressure and modify the tolerances. Please suggest
Old   November 7, 2014, 03:54
Tobi's Avatar
Tobias Holzmann
my simulations are running on 40 cores 2 weeks ...
But you time step is very small and your density is wrong (I think)
rho max/min : 2 0.5
you make something wrong.
I dont know what because you do not share many details. You should check out you time steps... maybe your pressure, velocity, k, epsilon are expoding. As I can see, you should use the correct form of the PIMPLE algorithm. Maybe it will be stabilized. Checkout my blog or also available at the wiki.
Keep foaming,
Tobias Holzmann
Study of the EEqn.H in rhoPimpleDyMFoam. Horacio Aguerre OpenFOAM Programming & Development 11 August 19, 2022 03:47
Developing a rhoPimpleDyMFoam solver bvieira OpenFOAM Programming & Development 20 October 9, 2014 13:12
rhoPimpleDymFoam jvd.mechanic OpenFOAM Running, Solving & CFD 0 June 15, 2014 06:20
Divergence in rhoPimpleDyMFoam bvieira OpenFOAM Running, Solving & CFD 1 July 19, 2012 03:22
