Problem of temperature propagation with the use of cyclicAMI
Old   October 21, 2014, 11:25
Default Problem of temperature propagation with the use of cyclicAMI
Laurent DASTUGUE
laurentD is on a distinguished road
Hello everybody,
currently i have to use unconformal meshes for a heat transfer problem.
I use for it the patch cyclicAMI at the boundary between the two differents meshes. I can see that the velocity is propagating with a logic evolution, but when i look the temperature field, i can see that this quantity doesn't propagate through this boundary, like if there is a wall...
i use cyclicAMI for the type of boundary for both U and T.
Do you know another boundary type i can use with a cyclicAMI patch to avid this problem ? Or another tip to help me ?
Thank you for your response.
Laurent
laurentD is offline   Reply With Quote
Problem with Turbulent Heat Flux Temperature boundary condition Manuel CFD OpenFOAM Running, Solving & CFD 11 March 17, 2016 16:12
Defining of initial temperature of certain body in unsteady heat transfer problem toodrunktorun FLUENT 1 September 5, 2013 10:34
same static and total temperature problem preetam69 FLUENT 1 August 15, 2013 18:17
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
HELP!: swimming pool flow problem Tee FLUENT 1 September 8, 2005 09:29
