fvDOM bugs in 2D? (can only be 2D in X-Y plane)
Old   October 21, 2014, 07:17
Default fvDOM bugs in 2D? (can only be 2D in X-Y plane)
Yuehan
wc34071209 is on a distinguished road
Hello everybody,
These days I just tested the radiation models in OpenFOAM, as enlightend by this post:http://www.cfd-online.com/Forums/ope...n-problem.html
However, I found a few problems. One is that the view factor model seems to show no regards to 'empty' b.c. (I hope I am wrong here, but if I am indeed wrong I hope to corrected by you), which has been put in an independent post.
And regarding fvDOM, it seems you can only put your 2D geometry within X-Y plane. I took a look at the source code fvDOM.C and starting from line 88
       if (mesh_.nSolutionD() == 2)    //2D (X & Y)
            scalar thetai = piByTwo;
            scalar deltaTheta = pi;
            nRay_ = 4*nPhi_;
            IRay_.setSize(nRay_);
            scalar deltaPhi = pi/(2.0*nPhi_);
            label i = 0;
            for (label m = 1; m <= 4*nPhi_; m++)
                scalar phii = (2.0*m - 1.0)*deltaPhi/2.0;
                IRay_.set
                    i,
                    new radiativeIntensityRay
                        *this,
                        mesh_,
                        phii,
                        thetai,
                        deltaPhi,
                        deltaTheta,
                        nLambda_,
                        absorptionEmission_,
                        blackBody_,
                        i
                i++;
So I don't know why OF developers do not consider other 2D situations.
wc34071209 is offline   Reply With Quote
Old   October 23, 2014, 10:36
chriss85 will become famous soon enough
Probably because of time/resources constraints...feel free to submit a patch!
chriss85 is offline   Reply With Quote
Old   October 23, 2014, 16:24
Yuehan
How and where to do that?
Old   October 24, 2014, 03:53
Bug tracker is here: http://www.openfoam.org/bugs/
For submitting patches, I think Github is the way to go: https://github.com/OpenFOAM/OpenFOAM-2.3.x
Using a Plane id in Fluent UDF cdf_user Fluent UDF and Scheme Programming 13 October 17, 2023 01:06
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Plane stress and plane strain cases for stress analysis Sargam05 OpenFOAM 0 May 3, 2013 19:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
