Problem solving a cylinder case 2d. Simple Foam |
October 16, 2014, 16:51 |
Esteban Vargas
Rep Power: 12 |
Hello.
I'm trying to solve a problem in 2 dimensions. The problem consists in flow around a cylinder. The inlet velocity is 0.1 m/s the pressure is 0, the fluid is water so I've already changed the viscosity in transport properties. But when I run the code this is the result. And in Parafoam I can't see a full development of the problem. It seems that I don't get any type of result. The fluid is considered as external flow. I'm using OF2.3 and meshing in gmsh. PHP Code:
I really appreciate that somebody can help me! Thanks to all who support me. The files are here. https://www.dropbox.com/s/87h6ekxf9p...ce.tar.gz?dl=0[/QUOTE] |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
a problem with convergence in buoyantSimpleFoam | skuznet | OpenFOAM Running, Solving & CFD | 6 | November 15, 2017 12:12 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Mass conservation problem with compressibleInterDyMFoam | LESlie | OpenFOAM Running, Solving & CFD | 4 | July 21, 2015 04:05 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
