October 15, 2014, 06:32 |
Floating object in interDyMFoam
Hao Chen
I am wondering that for the floating object tutorial in interDyMFoam, the object is not treated as a boundary but also a part of a domain? It seems that it creates a subset mesh and impose boundary condition on the subset mesh, but inside it there is still water? When I do the post-processing, I can not see the object.....I attached the figure. Best regards Hao |
March 19, 2015, 07:37 |
Rep Power: 12 |
I wasn't sure that you still need the answer or not.
However, if you haven't find it out, you can follow the way that I do. 1. In the volume Fields, check the alpha.water. Then "apply" it. 2. Use the filter "contour" and set the value of alpha is 0.5. If you like you can set the color to be blue. 3. Open another floatingObject.OpenFOAM file, and only select floatingObject in the Mesh Parts Then you may able to see something like the attached photo. |
May 4, 2015, 11:44 |
#3 | |
Hao Chen
Hi Chun,
Thanks a lot for your reply. I am not sure which version you use, but I use foam extend 3.1, and actually I did not find any floating object in the mesh parts. It is purely water and air... Best regards Hao Quote:
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 15:56 |
floating object | Maimouna | OpenFOAM | 13 | November 8, 2013 12:09 |
Floating object with 6DoF in InterDyMFoam | wavytracy | OpenFOAM Programming & Development | 2 | November 5, 2010 11:28 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 05:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
