November 3, 2014, 02:37 |
#21 |
Philipp
Rep Power: 27 |
Yes, I saw these pressure wiggles as well in my cases, but I didn't pay too much attention to them. I don't know if they are due to bad numerical settings or some bug in the code. Perhaps you can write a bug report with that small test case.
The skeleton ran out of shampoo in the shower. |
October 13, 2017, 04:31 |
#22 |
Vino
Rep Power: 13 |
Dear ArathoN and Philipp,
I am trying to simulate square duct problem (Re=3500) using cyclic inlet outlet with fvOptions. I am using OpenFOAM 4.1 with simpleFoam with k-epsilon model. I am not getting convergence for pressure & cross stream velocities. However, I am getting fully developed velocity profile in stream wise direction. Also, gradP term reaches steady state. Could you please give me your suggestions to improve the convergence? The case file that I used is available in the following link: https://github.com/vino-123/square_duct_cyclic_inout The following are the convergence I got with above case settings. Convergence: https://drive.google.com/open?id=0B1...2hnUkVjQkZtVjQ gradP: https://drive.google.com/open?id=0B1...3ZLeDhieGd2ZEU Ubar: https://drive.google.com/open?id=0B1...ktVM3NmOExNcU0 Thank you very much for your help. |
channel, cyclic, openfoam, pimplefoam |
How to setup cyclic BCs in simpleFOAM | hhuang84 | OpenFOAM Running, Solving & CFD | 14 | December 8, 2016 11:39 |
Possible createPatch/createBaffles bug? | simpomann | OpenFOAM Bugs | 2 | July 15, 2014 07:07 |
renumberMesh and cyclic BC's | Jonathan | OpenFOAM Pre-Processing | 3 | November 23, 2013 05:25 |
Adjusting velocity using cyclic bc's | gregdB | Main CFD Forum | 0 | January 25, 2012 09:08 |
Cyclic BCs using createPatch in OF 1.6.x | SunnyPP | OpenFOAM | 2 | August 6, 2010 10:21 |
