Generate continuous drops using "setFields" (or something similar) periodically
Old   October 10, 2014, 14:59
Default Generate continuous drops using "setFields" (or something similar) periodically
suchi89 is on a distinguished road
I am trying to model droplet train impact. So, I need to prescribe a particular drop size and velocity every "x" milliseconds. If I was required to only initialize the case with a drop (size and velocity), I could use setFields or funkySetFields to do so. But now I require to do this at regular time intervals. Anyone done the same?
Would appreciate any help / ideas on how to do the same!
Thanks!
suchi89 is offline   Reply With Quote
Old   June 1, 2015, 08:21
domenico
dome90 is on a distinguished road
I have the same problem. Did you solve your problem? I need help
dome90 is offline   Reply With Quote
Old   July 3, 2017, 13:39
Anastasios
ageorg is on a distinguished road
I have the same problem I want to patch periodically bubbles at the same location within a channel that liquid is flowing. Did you had any chance with the droplet train?
ageorg is offline   Reply With Quote
Old   October 30, 2023, 12:41
Aniket
meaniket is on a distinguished road
Hi!
Any luck with genrerating droplet/bubble train?
meaniket is offline   Reply With Quote
drop train, droplet, impact, periodic, setfields
