[interFoam] pipe flow - phase piling up at outletpatch ?!
Old   October 6, 2014, 17:41
Default [interFoam] pipe flow - phase piling up at outletpatch ?!
MangoMango is on a distinguished road
I need to simulate a turbulent twoPhase pipe flow.
The is set up with interFoam.
It works fine until the liquid phase hits the outlet-patch - then the pipe will fill up. No "drop" of the liquid Phase passes the boundarypatch. I know that it has to be a problem with the bc ...I tried several bc inletOutlet, pressureInlet ...but I cant figure out a way that will bring both phase through the patch.
https://www.wuala.com/awarth/Cloudbe...y=95tBfztyiTiN
It would be great if anyone could give a glance at this....Im somehow puzzeld.
best regards
Alex
MangoMango is offline   Reply With Quote
Old   October 6, 2014, 17:58
..I forgot a proper pic...sry
boundary condition, interfoam, outlet, two phase
Gravity/Buoyancy/Buoyancy reference density in two phase flow sharifi CFX 10 June 9, 2014 11:23
two-phase flow with a single phase simulation caunima Fluent Multiphase 0 October 28, 2013 03:42
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 20:01
pulsating static pressure around zero at pipe flow David Kim FLUENT 0 May 16, 2006 14:47
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
