Where to find information on dictionaries
Old   October 6, 2014, 12:51
Default Where to find information on dictionaries
Mattia Tamellini
mattia is on a distinguished road
Hi everyone!
I hope I chose the right section to post to.
I was wondering where I could find some information on the various dictionaries used by OpenFOAM. I feel that the documentation is somewhat lacking in this sense: when I need to use something that is not covered in the user guide, where can I find information about it? I know there are the tutorials too, but the various utilites are only used and never explained or commented upon.
More precisely, I am currently trying to solve a multiphase moving mesh case similar to the one shown in the interDyMFoam/DTCHull tutorial, but I am finding it difficult to proper set up the dictionary since I don't know where to find some kind of list with all the possible entries for the dynamicMeshDict and their meaning. Also the wiki page (http://openfoamwiki.net/index.php/Ma...m#Dynamic_Mesh) was not helpful, since it is too concise.
Can you please point me to some references where the less basic OpenFOAM utilities are explained?
Thanks in advance
mattia is offline   Reply With Quote
Old   October 6, 2014, 13:22
Vito Fasano
vitokad is on a distinguished road
Hi Mattia,
if I understand what you are searching, in the installation directory of OpenFOAM there are all dictionaries with all commands that you can use. If you do a search in the directory, for example "controlDict", you'll find a file called "controlDict" with all the commands that you can use. Copy it in your simulation's directory and modify it
vitokad is offline   Reply With Quote
Old   October 7, 2014, 05:23
Mattia Tamellini
Hello Vito,
thanks a lot for the reply!
I am not sure I understand what you mean though. If I search for "dynamicMeshDict" in my OpenFOAM installation folder, this is what I get:
mattia@replicant:~$ of230
mattia@replicant:~$ cd $WM_PROJECT_DIR
mattia@replicant:OpenFOAM-2.3.0$ pwd
/home/mattia/OpenFOAM/OpenFOAM-2.3.0
mattia@replicant:OpenFOAM-2.3.0$ find . -name "dynamicMeshDict"
./tutorials/combustion/PDRFoam/flamePropagationWithObstacles/constant/dynamicMeshDict
./tutorials/multiphase/interFoam/laminar/damBreak/constant/dynamicMeshDict
./tutorials/multiphase/LTSInterFoam/DTCHull/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/mixerVesselAMI/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/sloshingTank3D/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/sloshingTank3D6DoF/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/testTubeMixer/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/sloshingTank2D3DoF/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/damBreakWithObstacle/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/sloshingTank3D3DoF/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/floatingObject/constant/dynamicMeshDict
./tutorials/multiphase/interDyMFoam/ras/DTCHull/constant/dynamicMeshDict
./tutorials/multiphase/compressibleInterDyMFoam/ras/sloshingTank2D/constant/dynamicMeshDict
./tutorials/multiphase/interPhaseChangeDyMFoam/propeller/constant/dynamicMeshDict
./tutorials/multiphase/interMixingFoam/laminar/damBreak/constant/dynamicMeshDict
./tutorials/mesh/moveDynamicMesh/SnakeRiverCanyon/constant/dynamicMeshDict
./tutorials/mesh/foamyHexMesh/mixerVessel/constant/dynamicMeshDict
./tutorials/incompressible/pimpleDyMFoam/propeller/constant/dynamicMeshDict
./tutorials/incompressible/pimpleDyMFoam/mixerVesselAMI2D/constant/dynamicMeshDict
./tutorials/incompressible/pimpleDyMFoam/wingMotion/wingMotion2D_pimpleDyMFoam/constant/dynamicMeshDict
./tutorials/incompressible/pimpleDyMFoam/oscillatingInletACMI2D/constant/dynamicMeshDict
./tutorials/incompressible/pimpleDyMFoam/movingCone/constant/dynamicMeshDict
./tutorials/compressible/rhoPimpleDyMFoam/annularThermalMixer/constant/dynamicMeshDict
./src/dynamicFvMesh/dynamicRefineFvMesh/dynamicMeshDict
The only file I thought might be what you were referring to is the last one, but I'm afraid it does not contain what I was looking for:
mattia@replicant:dynamicRefineFvMesh$ cat dynamicMeshDict
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
//dynamicFvMeshLib   "libtopoChangerFvMesh.so";
dynamicFvMesh      dynamicRefineFvMesh;
//staticFvMesh;
mixerFvMeshCoeffs
    coordinateSystem
        type            cylindrical;
        origin          (0 0 0);
        axis            (0 0 1);
        direction       (1 0 0);
    rpm             10;
    slider
        inside      insideSlider;
        outside     outsideSlider;
// Refinement
dynamicRefineFvMeshCoeffs
    // Refine every refineInterval timesteps
    refineInterval 3;
    // Maximum refinement level (starts from 0)
    maxRefinement 2;
    // Maximum cell limit (approximate)
    maxCells 1000000;
    // volScalarField to base refinement on
    field gamma;
    // Which cells to un/refine: based on point values (simple averaging).
    // - refine pointCells of point value inbetween minLevel..maxLevel
    // - unrefine pointCells that are within nBufferLayers of points marked
    //   for refinement.
    minLevel 0.01;
    maxLevel 0.99;
    nBufferLayers 1;
    // Newly introduced patch points optionally get projected onto a surface
    //projectSurfaces ("fixedWalls4.stl");
    //projectPatches (fixedWalls);
    // Maximum project distance
    //projectDistance 1;
    // Fluxes to adapt. For newly created faces or split faces the flux
    // gets estimated from an interpolated volVectorField ('velocity')
    // First is name of the flux to adapt, second is velocity that will
    // be interpolated and inner-producted with the face area vector.
    correctFluxes ((phi U));
Did I misunderstand your suggestion?
Thanks again for your help
Old   October 7, 2014, 10:05
Vito Fasano
You understand right, but it is strange there is not a general dynamicMeshDict file that contains the possible commands..I'll try to look on my computer and I'lltell you
Old   October 8, 2014, 06:06
Mattia Tamellini
Ok, I'll wait for your reply! Thanks a lot
documentation, dynamic mesh
ERROR: unable to find library HJH CFX 6 February 26, 2019 07:52
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
interchanging face information with cell information/ radiation flux UDF ximik FLUENT 1 May 4, 2011 17:34
where can I find the information about "common block"? mactonald Siemens 5 June 15, 2009 02:46
where can I find the information about all the common block? mactonald STAR-CD 0 May 31, 2009 05:49
