Running a simple flow through an orifice
Old   October 4, 2014, 19:07
Default Running a simple flow through an orifice
Raghav
raghav.venky is on a distinguished road
I learning OpenFOAM for about a month. I'm trying to run a simple 2D flow through an orifice. I think the problem is similar to the Cavity one in the tutorial. The problem and the mesh that i generated using blockMesh is attached. I'm using icoFoam as the solver. This is the error I get:
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux              : 1.78803e-08
Specified mass inflow   : 4.5e-07
Specified mass outflow  : 0
Adjustable mass outflow : 2.32581e-53
    From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
    in file cfdTools/general/adjustPhi/adjustPhi.C at line 118.
FOAM exiting
This is the boundary condition for u:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0.001 0 0);
    outlet
        type            zeroGradient;
    fixedWalls
        type            fixedValue;
        value           uniform (0 0 0);
    master1
        type            fixedValue;
    master2
        type            fixedValue;
    topAndBottom
        type            empty;
I've given the velocity boundary condition at the outlet as zeroGradient. So I don't know why the continuity equation shouldn't satisfied.
Can someone tell me where I'm making a mistake?
raghav.venky is offline   Reply With Quote
Old   October 4, 2014, 21:26
Raghav
I tried tinkering around. I made the mesh very fine and deltaT very low so that the Courant number is very low. When I run it, it solves for a few time steps and the Courant number increases (order of 0.01) then gives out the same mistake again. I figured this could be because the fluid does not reach the outlet. So I gave a initial velocity for the internal flow field same as that of the inlet velocity. The solver seems to run fine, though I'm not sure if I'll the right answer.
Can someone explain physically and computationally whats happening here?
PS: I had attached a wrong image of the problem before. Correct image attached now.
Old   October 5, 2014, 10:26
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
it'll be easier to answer your question if you post case files. Right now I can only try to guess that you've got problems with boundaries (boundaries near the orifice to be more exact).
alexeym is offline   Reply With Quote
Old   October 6, 2014, 16:29
Matthew
MPD78 is on a distinguished road
Yes, please attach your case.
MPD78 is offline   Reply With Quote
Old   October 10, 2014, 13:25
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Although I am guessing here, I think you should actually change the boundary conditions in your p file. For the outlet you should use:
outlet
     type     fixedValue;
     value   uniform 0;
In fact your flow looks more like the pitzDaily (1 inlet, 1 outlet) tutorial than the cavity (only walls).
Regards,
Tom
tomf is offline   Reply With Quote
Old   October 19, 2014, 22:38
Raghav
Thanks @tomf, setting the outlet pressure to 0 worked. Thanks!
Old   September 4, 2020, 09:50
Default Openfoam flow in orifice
NikBomb is on a distinguished road
Does anyone have the case files for this problem?
NikBomb is offline   Reply With Quote
incompressible flow, orifice plate
Compressible flow through an orifice callumso OpenFOAM Running, Solving & CFD 4 April 4, 2013 16:08
Need help in modeling flow through orifice kunal Main CFD Forum 0 April 16, 2010 10:12
SIMPLE method for inviscid flow abcdef123 Main CFD Forum 0 February 26, 2010 09:24
Orifice Flow John Eichler Main CFD Forum 1 November 6, 2002 13:26
Supercritical steam flow through orifice (/nozzle) Miqu Lehtinen Main CFD Forum 1 June 22, 1999 14:43
