Advice on what solver I should use...
Old   October 1, 2014, 11:42
Default Advice on what solver I should use...
Jos E.
jelzinga is on a distinguished road
I am trying to run simulations in OpenFOAM (2.3) on air-bearings.
In the past I did simulations to see the transient effects on air-bearings with "sonicFoam"-solver.
It was often unstable (leading to crashes too), mostly because I only know the inlet pressure (6 bar) and the outlet pressure (1 bar) and I understood solving a pressure-pressure system is hard work.
However, nowadays I need to do simulations in order to get the steady-state solution of air-bearings, and not the transient situations. Essentially we want to know the pressure p in every cell inside the mesh to perform calculations based on that.
I can imagine a steady-state solver would be faster than a transient-solver as sonicFoam. And perhaps more stable too...
What solver do you recommend? and why ? If necessary, I can give you a copy of my current case folder so you can see the mesh and setup.
jelzinga is offline   Reply With Quote
Time dependent solver of unsteady Navier Stokes Mehrez COMSOL 10 March 20, 2024 04:57
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
2D isothermal cylinder not converging UPengineer OpenFOAM Running, Solving & CFD 7 March 13, 2014 06:17
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 13:44
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 08:45
