velocity inlet definition
Old   September 27, 2014, 16:47
Default velocity inlet definition
Ali reza
1988 is on a distinguished road
hello everyone
I have simulated fluid flow in a pipe. velocity inlet was defined at the inlet of the pipe . I want to set the velocity profile the same as which has been shown in the picture. this function does not have an specific definition so I think I have to define it by list of digits which is consist of velocities and times.
I have no idea about defining these digits as a velocity inlet in Openfoam, please help me to solve the problem.
thanks
1988 is offline   Reply With Quote
Old   September 28, 2014, 07:28
Ali reza
should I define it in this way?
OpenFOAM table file
uniformValue     tableFile;
tableFileCoeffs
    fileName     "$FOAM_CASE/myDataFile"
    outOfBounds  clamp;
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
How to apply an outlet velocity profile to another inlet? siw FLUENT 4 April 10, 2013 12:19
Velocity Inlet BC -- Flow Reversal salihovic FLUENT 0 May 8, 2011 06:45
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 16:35
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
