Boundary conditions for Two-phase Flow with Different Inlet Pressures |
November 9, 2016, 05:46 |
#21 |
Milad
Rep Power: 11 |
Thanks for sharing the information. Good job, I guess you are simulating the vertical 2P flow. But let's talk about horizontal flow since I am simulating horizontal cases now. Actually for the superficial velocities, I was thinking since we already set the value of velocity at the inlet, it means we have same actual velocity for both phases(vg=vl=v). Also we set the alpha to a certain value. So we would have the following equation: Liquid superficial vel.=U*alpha Gas Superficial vel.=U*(1-alpha) Am I wrong? Regarding your mention about Titel-Dukler map, still to use that flow map we need to somehow find the correct value for corresponding velocities in our simulation. Because if you loot at the vertical axis, there is still velocity behind the parameters! Also, regarding your current model, are you able to simulate slug or annular flow (for horizontal case)? Thank you, |
November 9, 2016, 07:13 |
#22 | ||
Paul Palladium
Rep Power: 10 |
It means that the mass flux of the mixture is equal to the sum of two terms. One for each phase: Be careful, in OPENFOAM alpha = 1 means "water". Usually in the literature it's the opposite. Quote:
Yes... I am really not sure if it's possible to predict the flow regime only using superficial velocity at inlet. Aee explained it very well in a previous post. From my point of view is constant at any section of the pipe (if we suppose that the flow is "stationary"). But the two components of change as the flow develops. rise when decrease in order to maintain constant. I guess it's not the good way to take this problem. PS : sorry for my very bad English... EDIT : I changed my notation. I replaced by . It's less confusing |
November 9, 2016, 22:59 |
#23 |
Milad
Rep Power: 11 |
Thats correct. But is that against the reality? I mean even for a real physical sense, this will happen, right? As you know, the well-know flow regime maps for predicting adiabatic two-phase flow (such as Mandhane, Taitel-Dukler,...) are based on superficial velocities of gas and liquid. I think even in those flow maps, the values of superficial velocities represent the inlet ones as it changes by developing the flow. The same thing happens here in the simulation, and it should be possible to use the flow map by superficial velocities of the phases. (Please correct me if I am not true) If you look at this paper: http://ccsenet.org/journal/index.php...cle/view/42063 They compared their 2D simulation with Taitel-Dukler map, however, when I tried to calculate the parameters in Table 2, I could not get those values for X, F and T. for example for the case (U=0.1 and alpha=0.1) how they ended up with X=40.7696, F=0.0014 and T=0.0432? |
November 10, 2016, 01:33 |
#24 | |
Milad
Rep Power: 11 |
Jl=alpha*vl Jg=(1-alpha)*vg I've attached 3 screenshot out of my 2D simulations hereby. The geometry of all the cases are 1m * 11mm The first one is for 11000 mesh (1000*11) whereas U=0.3 , alpha=0.5 using RAS turbulence model. The flow is stratified. The 2nd one is for 44000 mesh (2000*22) with U=0.59 and alpha=0.6 ( I don't know exactly about this flow regime type, probably similar to slug flow) The 3rd one is for another inlet condition which I used to use earlier. the inlet is just divided to 7 separate inlet (3 for gas and 4 for water). I used 198000 mesh (3000*66) and the flow is plug regime. However, as Aee said before, this is not physical as there should be always gradient between neighbors. But the result shows something at least. Yet I cannot capture wavy and annular flow from my model. I even used very fine mesh (up to 790000 cells with various values for alpha and U). I was wondering if you can get from your model or not. Thank you, Milad |
November 10, 2016, 10:21 |
#25 | ||
Paul Palladium
Rep Power: 10 |
Thanks for you reply. I knew the paper of our Russians friends. Very interesting. I got same problem than you. I wasn't able to capture annular flow but I had small wave on another one. Quote:
In fact I think the problem come from the length of the pipe. If the length is too short the flow regime can't develop (do you agree ?). Did you try to run your simulation on a 10 m pipe ? Actually I am simulating different flows patterns on a vertical pipe (because it's run faster and I have only 9 cores on my workstation). Paul |
November 10, 2016, 13:09 |
#26 | |
Milad
Rep Power: 11 |
BTW, have you simulated two phase flow in a 3D pipe instead of 2D? I wonder if the only difference between 2D and 3D simulation should be just creating the geometry or is there any other difference? Actually, I've just recently started to simulate in a 3D pipe, but still I am keep using the similar boundary conditions and system files for my simulation. However, I am not pretty sure if that should work or not. Thanks, Milad |
November 11, 2016, 04:06 |
#27 | |
Paul Palladium
Rep Power: 10 |
November 11, 2016, 05:26 |
#28 | |
Paul Palladium
Rep Power: 10 |
Yes it works. You just need to use rigorously Froude Number, Lockhart–Martinelli parameter and Taitel/Dukler parameter (well described on page 2 and 3). For the case (U=0.1 and alpha=0.1) the regime is laminar. Use 64/Re for the friction factor. When it's turbulent I used Blasius' correlation (0.3164Re^(-0.25)). Be careful there is a mistake in their paper. They have forgotten the square on the velocity (formula 4, page 3). Paul |
November 13, 2016, 13:22 |
#29 | |
Milad
Rep Power: 11 |
Thanks, Milad |
November 13, 2016, 14:03 |
#30 | |
Paul Palladium
Rep Power: 10 |
November 13, 2016, 15:27 |
#31 | |
Milad
Rep Power: 11 |
The gas is air and air density is 1.2 kg/m3. https://en.wikipedia.org/wiki/Density_of_air If you are saying this is not correct. What would be true value then? Thanks, Milad |
November 13, 2016, 15:40 |
#32 | |
Paul Palladium
Rep Power: 10 |
November 13, 2016, 17:21 |
#33 |
Milad
Rep Power: 11 |
U=0.1 , alpha=0.1 ---> Jg=U(1-alpha)=0.1(1-0.1)=0.09
Dh=0.08 kinematic viscosity of gas (nug)=1.48*(10^-5) Reg=Jg*Dh/nug = (0.09)(0.08)/(1.48*10^-5)=486.5 !!!!!!!!! About the gas density I said in my previous post that if the gas is air, the authors did a mistake on the paper as the correct value of air density is 1.2 kg/m3 not 12. However, even choosing 12 as air density, this value has nothing to do with calculating the Reynolds number as long as we already have the kinematic viscosity. Thanks, Milad |
November 13, 2016, 17:34 |
#34 | |
Paul Palladium
Rep Power: 10 |
Paul. |
November 15, 2016, 18:24 |
#35 | |
Milad
Rep Power: 11 |
December 7, 2016, 00:27 |
Grid dipendency
#36 |
Milad
Rep Power: 11 |
For this kind of problem which criteria is best to check the grid dependency? which parameter you usually used in two-phase flow to show that the case is mesh independent?
Thanks, Milad |
August 8, 2018, 14:09 |
Slug flow in horizontal pipeline
#37 |
Udayraj Thorat
Rep Power: 8 |
Hello everyone,
I am simulating gas-liquid two phase flow in a horizontal pipeline of L/D ratio 150. I have divided the inlet in two parts. I am entering water at 0.2m/s and air at 1.2m/s. The volume fraction of water at water_inlet is 1. The solver scheme used is PISO and PRESTO for pressure. The mesh is fine with 1.6 M cells. The flow initially converges and start diverging after some time steps. what could be the reason behind it? your reply is highly appreciated. Thank you. |
September 25, 2018, 21:55 |
#38 | |
katia
Rep Power: 8 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
How to specify an inlet boundary conditions for a fully developed gas flow in a duct. | legendyxg | FLUENT | 2 | May 11, 2010 08:32 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
Pulsating flow with non-reflective inlet boundary | cc1000 | CFX | 6 | April 27, 2009 09:10 |
Boundary conditions for two phase flow | Adel Ataki | FLUENT | 2 | November 9, 2000 05:24 |
