floating point exception error by thermophysical properties in rhoSimpleFoam
Old   September 24, 2014, 07:18
Default floating point exception error by thermophysical properties in rhoSimpleFoam
Rajeev KT
RAJEEV is on a distinguished road
Hi , I am using rhoSimpleFoam (openfoam 2.1.1) in parallel, for Nozzle with external flow... Flow conditions is M=0.8, M=0.9, SL, ISA... I've attached the openfoam folders having boundary conditions and other files for M=0.8 and using k-Epsilon turbulence model (also some pictures showing model, domain n velocity contours with turbulence off). initially it was giving error with floating point exception by thermophysical properties...... after going through some of the threads here I changed the Bc's and relaxation factors also... now it is running with turbulence off, but when i switch on turbulence i still get same error ... can anybody help me out?
RAJEEV is offline   Reply With Quote
Old   September 25, 2014, 04:23
Rajeev KT
Is anybody there?
floating point exception, nozzle, rhosimplefoam
Floating point exception with pimpleDyMFoam ebah6 OpenFOAM Running, Solving & CFD 9 November 1, 2017 06:58
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 11:21
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 17:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 04:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
