modelling a fan on a Boundary patch
Old   September 23, 2014, 11:38
Default modelling a fan on a Boundary patch
coroi is on a distinguished road
Hi OpenFOAMers,
I would like to know your opinion on how to model a fan via boundary conditions already existing in OpenFOAM.
My purpose is to get a fixed flowrate on the Fan_patch, in order to model the ventilation in a room.The direction of the flow points outwards the room.
I was thinking to set a outletInlet BC in the file 0/U for the patch and fixedValue BC for the pressure.
I tried to implement the existing fan BC (according to the TJuctionFan tutorial in OpenFOAM2.1.1 ) and fanPressure BC but my computations stop at the 1st time iteration, the solver fireFoam crashes because a "floating point" exception" signal is sent to the CPU.The solution isn't normally diverging because the max Courant number is 0.0008 << 0.5 .
Does anyone have any suggestions/comments on how to model the fan on a boundary patch or how to make work the fan/fanPressure BC on interior baffles??
I'll appreciate any help!!
Thank very much for all your posts on that forum!!Some of them ae very helpful!
coroi is offline   Reply With Quote
Old   October 30, 2014, 10:01
Joachim Herb
jherb is on a distinguished road
If you want a fixed flow rate, why don't you use a standard boundary condition for the velocity? You could try fixedMean (to only specify the mean value of the outflow) or surfaceNormalFixedValue (be careful with the sign/direction).
jherb is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 13:46
