Drag force coefficient too high for a flow past a cylinder using komega sst
Like Tree3Likes
Old   September 23, 2014, 09:19
Default Drag force coefficient too high for a flow past a cylinder using komega sst
Scabbard is on a distinguished road
Hi guys,
I am just start working with Openfoam simulating a 2D flow past a cylinder at Re=1e04, using komega-sst. But after several simulation my drag force coefficient is too high, it should be around 1.2, but I got 1.65
Here is my setting
cylinder diameter: 1m
flow velocity:1m/s
kinematic viscosity:1e-04
Re=1e04
y+ max=1.3
y+ min=0.03
y+average=0.6
Max aspect ratio=15.45
non-orthogonality max=40.76 average=12
lRef 1 (The diameter of the cylinder)
Aref 3.14 (the front area, my cylinder height is 3.14)
timestep 0.0005s
simulation time 200s
my k inlet is calculated as 1.5(UI)^2 U is the flow velocity. I is the turbulence intensity=2%
my omega inlet is calculated as kinlet^0.5/(l*Cmu^0.25) Cmu=0.09 l is the tubulence length l=0.07D=0.07
and my initial omega at wall is calculated as omega=10*6v/(beta*deltay^2) v is the kinematic viscosity beta=0.075 deltay is the first boundary layer thickness=0.0015
The flow inlet boundary is located 10D upstream from the centre of the cylinder and the flow outlet boundary is located 25D downstream from the center of the cylinder. The top and bottom boundaries are located at a distance of 10D from the center of the cylinder.
K
|  \\    /   O peration     | Version:  2.3.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.0006;
boundaryField
    INLET
        type            fixedValue;
        value           uniform 0.0006;
    OUTLET
        type            zeroGradient;
    CYLINDER
        type            kqRWallFunction;
        value           uniform 0;
    SYM1
        type            symmetry;
    SYM2
        type            symmetry;
    BACK
        type            empty;
    FRONT
        type            empty;
omega
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 0.6388;
boundaryField
    INLET
        type            fixedValue;
        value           uniform 0.6388;
    OUTLET
      type            zeroGradient;
    CYLINDER
        type            omegaWallFunction;
        value           uniform 35555.56;
    SYM1
        type            symmetry;
    SYM2
        type            symmetry;
    BACK
        type            empty;
    FRONT
        type            empty;
nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0.0;
boundaryField
    INLET
        type            calculated;
        value           uniform 0;
    OUTLET
        type            calculated;
        value           uniform 0;
    CYLINDER
	type            nutUSpaldingWallFunction;
        value           uniform 0;
    SYM1
        type            symmetry;
    SYM2
        type            symmetry;
    BACK
        type            empty;
    FRONT
        type            empty;
p
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    object      p;
internalField   uniform 0;
boundaryField
    CYLINDER
        type            zeroGradient;
    SYM1
        type            symmetry;
    SYM2
        type            symmetry;
    BACK
        type            empty;
    FRONT
        type            empty;
    OUTLET
        type            fixedValue;
        value           uniform 0;
    INLET
        type            zeroGradient;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (1 0 0);
boundaryField
    SYM1
        type            symmetry;
    SYM2
        type            symmetry;
    BACK
        type            empty;
    FRONT
        type            empty;
    CYLINDER
        type            fixedValue;
        value           uniform (0 0 0);
    OUTLET
        type            zeroGradient;
    INLET
	type fixedValue;
	value           uniform (1 0 0);
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default     CrankNicolson 0.5;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)       		  Gauss limitedLinearV 1;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
    div(phi,k)		Gauss limitedLinear 1;
    div(phi,omega)	Gauss limitedLinear 1;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DomegaEff,omega)	Gauss linear corrected;
laplacianSchemes
    default         		            Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          1e-02;
    pFinal
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0;
    nuTilda
        solver          PBiCG;
        tolerance       1e-06;
        relTol          0;
    UFinal
        solver          PBiCG;
        tolerance       1e-05;
        relTol          0;
    omega
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
    omegaFinal
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
    k
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
    kFinal
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    nOuterCorrectors         1;
    nCorrectors              2;
    nNonOrthogonalCorrectors 1;
    residualControl
       "(U|p)"
           tolerance 1e-04;
           relTol    0;
The time step is 0.0005, keep the co below 0.2
and I have try 30,000 and 60,000 elements mesh, both of them get the result Cd around 1.65.
my 30,000mesh is in attacehd
Also I have try the k at wall is
CYLINDER
value uniform 1e-2;
the drag coefficient still around 1.6
Could anyone give me some recommendations how to solve this problem? I saw somebody post this question before. However there is no solution for the problem
Thank you all of you.
Best regards,
Scabbard
Scabbard is offline   Reply With Quote
Old   September 24, 2014, 07:57
Hi guys,
Could anyone give some recommendations about this problem? I am really sick with this problem. Thank you for your help.
Best regards,
Scabbard
Old   September 24, 2014, 10:02
joegi
joegi.geo is on a distinguished road
I will put my two cents.
If you are reporting correctly the y+, you shouldn't use wall functions.
Set k and omega to fixedValue and use a small number (1e-8) or 0.
In my personal experience, using the k-o for these values of y+ if quite difficult to get good results, you better use a lowRe model. You can try the spalart-allmaras as well.
You can also tight the tolerance of U and UFinal to 1e-8, it doesn't cost anything.
jg
joegi.geo is offline   Reply With Quote
Old   September 24, 2014, 10:54
jg
Hi joegi.geo
Thank you for your kindly help. I will have try with your recommendation.
Best regards,
Scabbard
Old   September 26, 2014, 13:36
Saravana Kumar Lakshmanan
aerosaravanan is on a distinguished road
Hi Scabbard,
I am also having similar problem.My Re is 45000 almost all the settings are similar to you. I got good drag value but shedding frequency is very high. What about your case? are you getting correct shedding frequency.
aerosaravanan is offline   Reply With Quote
Old   September 26, 2014, 15:16
Originally Posted by aerosaravanan View Post
Hi Scabbard,
Hi aerosaravanan,
My shedding frequency is better than the drag coefficient. Tomorrow i will post on my case. I am really sick with this problem. Could you upload your case on the forum? Many thx with your help
Best wishes,
Scabbard
Old   September 27, 2014, 07:28
Dear Foamers,
I am really sick with this problem, I tried both Spalart-Allmaras and k omega-sst, both of them the drag coefficient are too high. Could anyone give me some recommendation about how to solve this? Thank you so much.
The two cases are in the link,
k omega sst
https://drive.google.com/file/d/0B1v...it?usp=sharing
Spalart-Allmaras
Best regards,
Scabbard
Old   September 27, 2014, 10:18
Hi Scabbard,
I don't have any recommendations.But after looking your case I found that you are using createPatchDict. Is that required for your case.You are defining symmetry on top and bottom right.Then try to use simple decomposition instead of scotch(To be honest I don't know about this influence but I am using simple and It's easy to decompose also).Otherwise every thing seems right.Today also I simulated my case with 65K cells for Re 45000.I got reasonable drag value of 1.19 the actual value is 1.17. But strouhal number is high which comes around 0.25, the actual one is 0.2.
Old   September 27, 2014, 10:23
Hi Scabbard,
As you asked. I am sharing my case. Hope It will help you.
https://drive.google.com/file/d/0B8S...it?usp=sharing
Old   September 27, 2014, 10:31
Hi Scabbard,
Hi aerosaravanan,
Thank you so much for your help. I will have a try to use simple not scotch. the create PatchDict is not used in this case. Sometimes I want to use the cyclic bc then I use this. By the way, how did you calculate the omega at the inlet? I found in your case your inlet omega even larger than the omega at the wall of cylinder?
http://www.cfd-online.com/Forums/ope...omega-sst.html
I found 3 way to calculate the omega at inlet. Which method is your choice?
Best wishes,
Scabbard
Old   September 27, 2014, 11:33
Hi Scabbard,
Hi aerosaravanan,
I saw your thread, we use the same method. I think if your drag force is accurate, the strouhal number should be accurate. Because the strouhal number is easier stable than Cd.
Best wishes,
Yibo
Old   September 27, 2014, 12:09
I took the equation from one journal paper.The equations are given below.This is exclusively for kOmegaSST model
For freestream:
k=(3/2)*(uinf*I)^2 where uinf-freestream velocity I-Turbulent Intensity(1% in my case)
omega=((k)^(3/2))/(k*cmu*l) where cmu=0.09 l=0.07D (D=dia of cylinder)
For wall
k=0
omega=(60*nu)/(beta*(dely)^2)
nu=kinematic viscosity beta=0.075 (constant) dely=first grid point value in m from wall.
Hope this will help for other newbie also...
No, the omega at wall is large check again.
Originally Posted by Scabbard View Post
Hi aerosaravanan,
Best wishes,
Scabbard
Carno and altinel like this.
Old   September 27, 2014, 12:12
Hi yibo,
No I am not getting the correct strouhal number.You can check the postprocessing folder in my case.The force coefficients are there.If possible you plot and check and even you can calculate the Cd also.
Hi aerosaravanan,
Best wishes,
Yibo
Old   September 28, 2014, 07:02
Hi yibo,
Hi aerosaravanan,
I try to use your settings on my case, still cd=1.6, I am wondering is it my domain too high (H=3.14D) and not wide enough, width =20D?
Best wishes,
Scabbard
Old   September 28, 2014, 07:37
Hi Scabbard,
Your domain size is fine.You used 25D downstream and 10D in upstream,Top & Bottom.This is reasonable value for cylinder analysis.But I don't have any answer for your drag value.Have you tried in other meshes/other Re.Because I tried to simulate for Re 1000, that time I got high drag value and correct strouhal number with the same settings.Some openfoam guru only can clear our doubts.Looking for your help foamers.
Old   September 28, 2014, 08:02
Hi Scabbard,
Hi aerosaravanan,
Re=1000 i think is laminar flow, so cannot use turbulence model to simulate it. Have you try 3900 re? I try either, but both of them give a high Cd value
Best wishes,
Scabbard
Old   September 29, 2014, 05:28
Julian Langowski
Ruli is on a distinguished road
Hi guys,
some considerations from my side:
- If you use RANS, you assume FULL turbulence. This is not necessarily the case at RE = 5 * 10^5. Try something like RE = 5 * 10^6 for validation and after that test lower Reynolds number.
- As you assume full turbulence, transition might not be predicted correctly. As far as I know, transition point is shifted in flow direction by RANS => You have less separation => The simulated CD should be too low.
- How is your Courant number?
- Concerning mesh dimensions: To be on the safe side, perform a mesh study => Systematically increasse wall distances until reference values are changing no more.
Just some guesses,
good luck!
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Old   September 29, 2014, 21:14
mhkenergy is on a distinguished road
Hi all,
I haven't read the entire details/results posted here but here is some information regarding the physics of the problem (flow over a smooth cylinder) and its problem with CFD:
1) Simulation of flow over bluff bodies have certain problems with RANS models. Flow regime for 1×10^3- 2×10^3 < Re < 2×10^4- 4×10^4 is called TRSL2 (Transition in Shear Layers, 2nd regime). This regime has a characteristic feature of formation of transition vortices in free shear layers. For smooth cylinders, separation point becomes oscillatory and there are important problems regarding the resolution of capturing this oscillatory movement of the separation point with RANS models. Since this plays a dominant role in the formation of vortices, low accuracy is usually the case.
2) I would dismiss the idea of using wall functions altogether for CFD of flow over bluff bodies. Avoiding details, it can be said that there are two types of vortex formation mechanisms seen in flow over circular cylinders: "D-scale" vortices that are on the scale of cylinder diameter and big number of very small vortices that are fed into the wake by the boundary layer. Even though transition to turbulence in boundary layers for flow past circular cylinders occurs around Re ~ 1-2 X 10^5, wall functions might fail to accurately approximate the vortex formation behavior.
The problem of correctly capturing the separation point is the biggest issue with RANS simulation of flow past smooth cylinders.
I'd recommend doing some literature search regarding the problem before trying to adjust your parameters. Even though my research focus is on the fluid induced motions of oscillating cylinders, my opinion is that such an attempt might be completely futile if the physics of the problem cannot be modeled properly with the way you are numerically trying to discretize.
ancolli likes this.
mhkenergy is offline   Reply With Quote
Old   September 30, 2014, 07:13
Originally Posted by mhkenergy View Post
Hi all,
Hi mhkenergy,
Thank you for your reply. I have read some papers doing URANS for a square cylinder on Re=21400, however both cylinder and square cylinder I can not get satisfied result. I am also doing work on vortex induced motion. I think sometimes using URANS is a easy way to validated the rigid body motion solver.
Also I am still confusing why other people can get a cd very close to the experiment result but mine is far away from the result.
Best regards,
Scabbard
Old   September 30, 2014, 07:42
Hi Scabbard,
I tried to simulate for Re 3900 with low reynolds model(LaunderSharmakepsilon). This time I got reasonable strouhal Number but high drag value.It's confusing me lot.
Then for your last post same thing happening for me.I got few papers on circular cylinder analysis in OpenFOAM for wide range of Re.And they got reasonable values like CD, strouhal number with komegaSST model.
Hi aerosaravanan,
Best wishes,
Scabbard
Modelling flow around a Smooth Cylinder - Drag coefficient HELP Asatorae STAR-CCM+ 17 November 14, 2014 11:45
Flow over 2D Cylinder, Laminar and Turbulent Tsr63 FLUENT 5 November 13, 2014 13:13
Flow past rotating cylinder: Problem with ForeCoeffs raf1111 OpenFOAM 1 December 16, 2013 10:45
interFoam solver for free surface flow past a circular cylinder tfuwa OpenFOAM Running, Solving & CFD 6 June 12, 2013 09:55
plotting drag coefficient in low reynolds number flow past cylinder atmcfd FLUENT 0 January 2, 2010 09:34
