Patchfield error
Old   September 19, 2014, 17:23
Default Patchfield error
Vineet
viv123 is on a distinguished road
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
    value        uniform 0;
    top
    type        zeroGradient;
    bottom
    type        zeroGradient;
    cylinder
    type        zeroGradient;
    sides
        type            empty;
This is the code in p file for flow over a circular cylinder. We are getting the error: cannot find patchfield entry for outlet. Please help.
viv123 is offline   Reply With Quote
Old   September 20, 2014, 01:44
Kaufman
kmefun is on a distinguished road
Could you post your test case?
kmefun is offline   Reply With Quote
Old   September 20, 2014, 01:56
Vineet
Hi kmefun,
The test case is simple flow past a circular cylinder to observe laminar vortex shedding. I am using pisoFoam solver for this. 0>>p file I have given in older thread.
0>>U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (1 0 0);
    outlet
        type            zeroGradient;
    top
    type        slip;
    bottom
    type        slip;
    cylinder
    type        fixedValue;
    value        uniform (0 0 0);
    sides
        type            empty;
I found this code in a tutorial online and in the tutorial the code is giving correct results but on my machine when I run the same code I get "Cannot find patchField entry for outlet" error.
Many thanks!
Old   September 20, 2014, 02:01
Vineet
blockMeshDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (-23 -25 0)            //0
    ( 23 -25 0)            //1
    (40 -25 0)            //2
    (-0.7071 -0.7071 0)        //3
    ( 0.7071 -0.7071 0)        //4
    (-0.7071  0.7071 0)        //5
    ( 0.7071  0.7071 0)        //6
    (-23 25 0)            //7
    ( 23 25 0)            //8
    (40 25 0)            //9
    (-23 -25 1)
    ( 23 -25 1)
    (40 -25 1)
    (-0.7071 -0.7071 1)
    ( 0.7071 -0.7071 1)
    (-0.7071  0.7071 1)
    ( 0.7071  0.7071 1)
    (-23 25 1)
    ( 23 25 1)
    (40 25 1)
blocks
    hex (0 3 5 7 10 13 15 17) (200 60 1) simpleGrading (0.20 1 1)
    hex (1 4 3 0 11 14 13 10) (200 60 1) simpleGrading (0.20 1 1)
    hex (4 1 8 6 14 11 18 16) (200 100 1) simpleGrading (5 1 1)
    hex (6 8 7 5 16 18 17 15) (200 60 1) simpleGrading (5 1 1)
    hex (1 2 9 8 11 12 19 18) (100 100 1) simpleGrading (1 1 1)
edges
   arc 3 5 (-1 0 0)
   arc 13 15 (-1 0 1)
   arc 4 6 (1 0 0)
   arc 14 16 (1 0 1)
   arc 5 6 (0 1 0)
   arc 15 16 (0 1 1)
   arc 3 4 (0 -1 0)
   arc 13 14(0 -1 1)
boundary
    inlet
        type wall;
        faces
            (17 7 0 10)
    outlet
        type wall;
        faces
            (9 19 12 2)
    top
        type wall;
        faces
            (8 7 17 18)
        (9 8 18 19)
    bottom
        type wall;
        faces
            (0 1 11 10)
        (1 2 12 11)
    cylinder
        type wall;
        faces
            (5 6 16 15)
        (16 6 4 14)
        (4 3 13 14)
        (3 5 15 13)
    sides
        type empty;
        faces
            (7 8 6 5)
        (7 5 3 0)
        (3 4 1 0)
        (8 1 4 6)
        (8 9 2 1)
        (18 17 15 16)
        (15 17 10 13)
        (14 13 10 11)
        (18 16 14 11)
        (19 18 11 12)
mergePatchPairs
Apart from this there are other files: controlDict, decomposeParDict, fvSchemes, fvSolution and the usual RASProperties, transportProperties, turbulenceProperties files.
Any help would be appreciated
Old   September 20, 2014, 12:38
Kaufman
blockMeshDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 1;
vertices
    (-23 -25 0)            //0
    ( 23 -25 0)            //1
    (40 -25 0)            //2
    (-23 25 0)            //7
    ( 23 25 0)            //8
    (40 25 0)            //9
    (-23 -25 1)
    ( 23 -25 1)
    (40 -25 1)
    (-0.7071 -0.7071 1)
    ( 0.7071 -0.7071 1)
    (-0.7071  0.7071 1)
    ( 0.7071  0.7071 1)
    (-23 25 1)
    ( 23 25 1)
    (40 25 1)
blocks
edges
   arc 3 5 (-1 0 0)
   arc 13 15 (-1 0 1)
   arc 4 6 (1 0 0)
   arc 14 16 (1 0 1)
   arc 5 6 (0 1 0)
   arc 15 16 (0 1 1)
   arc 3 4 (0 -1 0)
   arc 13 14(0 -1 1)
boundary
    inlet
        type patch;
        faces
            (17 7 0 10)
    outlet
        type patch;
        faces
            (9 19 12 2)
Old   September 21, 2014, 15:41
Vineet
Thanks for the reply.... Tried this but we are getting the same error
Old   September 21, 2014, 16:26
Vineet
Could you please take a look at this site. They have given a tutorial video and codes there. We are trying to run their exact code but getting this error.
http://www.comflics.de/2014/08/openf...-shedding.html
Thanks!
Old   September 22, 2014, 17:25
Kaufman
I download this test case and it is runing OK!
this is velocity field for 10 sec
Old   September 22, 2014, 17:32
Vineet
I don't know why I am getting this error.
Could you help me with a few points?
1. Which version of OpenFOAM did you use?
2. Did you clone it from GitHub or did you download the zip file?
I am unable to do both so I opened every file and copy-pasted the content of all the files.
Thanks a lot for your time!
Old   September 22, 2014, 17:54
Kaufman
I use OF 2.3
https://www.dropbox.com/s/ehb1f3hmub...dding.zip?dl=0
You can dowload the test case I ran above.
Old   September 22, 2014, 18:11
Vineet
This works! You are awesome!!
Thank you once again
Now I will try to find why earlier it was not working.
Old   October 14, 2014, 05:25
Vineet
I have been trying to simulate the case for flow over oscillating rectangular cylinder. In the blockMeshdict file, I removed the arc commands and changed the dimensions so as to make the bluff body and ran the same code for stationary rectangular cylinder. It ran for a time step of 0.025 second and then exited with an error. Any ideas regarding this?
Thanks in advance
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
