September 17, 2014, 06:17 |
k-omega turbulence model in ABLConditions
Cedric
Rep Power: 12 |
Hi, I'am trying to perform wind simulation on buildings.
I use the "turbineSitting" tutorial. Since I was reading documentation about turbulence model, I read that k-omega turbulence model is more "true" than k-epsilon model near walls. So I wonder if I can use k-omega model in ABLConditions and, if yes, what kind of boundary condition could I put on the inlet in the omega file in 0.org folder? Thanks for your help, Cedric |
October 29, 2014, 08:32 |
Joachim Herb
Rep Power: 22 |
Have look look at the SST turbulence model: It is k-epsilon in the "middle" of the flow and k-omega near the walls.
Fluent :- turbulence Model | prince_pahariaa | FLUENT | 9 | May 20, 2016 04:41 |
Implement an les turbulence model | pante | OpenFOAM Programming & Development | 19 | December 5, 2014 17:16 |
new turbulence model in Fluent | C.C | FLUENT | 0 | August 29, 2013 11:44 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
Transition kappa omega turbulence model | mannobot | FLUENT | 0 | June 9, 2010 05:11 |
