Rising Bubble Test Case Using interFoam: Unrealistic Results?! |
#21 |
Bushra Rasheed
Rep Power: 5 ![]() |
Hi!
I wanted to ask if you made an extra alpha.air file in this case while running interFoam. The default interFoam tutorials only have alpha.water files in setFieldsDict and in 0 folder. I want to get same result as yours but unable to do so with interFoam. Any help will be appreciated! Thanks! |
#22 |
Bushra Rasheed
Hi!
Has anyone tried the same problem with orifice? I have defined constant flow rate at orifice inlet but bubbles formed are not realistic |
interfoam, rising bubble, unrealistic |
bubble rising problem | swamysrikanth | ANSYS Meshing & Geometry | 3 | May 31, 2016 11:09 |
bubbleFoam - Simple case, Large bubble, closed domain | darai | OpenFOAM Running, Solving & CFD | 9 | October 12, 2015 05:40 |
3D rising bubble view in paraFoam post-processing | tayo | OpenFOAM Post-Processing | 1 | September 27, 2012 07:03 |
bubble rising in a column | swamysrikanth | Main CFD Forum | 2 | September 27, 2010 08:59 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 18:46 |
