Compressible Pressure Driven Flow
Old   August 18, 2014, 16:23
Post Compressible Pressure Driven Flow
Matei Petrescu
mateiu2003k is on a distinguished road
Hello everyone,
I am pretty new and inexperienced with openFOAM (I am currently using version 2.1.1). My goal is to simulate a the flow of a cold gas (Helium at 77K) through a nano-pipe. I have started with the simplest case: incompressible Helium gas at room temperature and macro-pipe (several millimetres in diameter and pretty long). I have used icoFoam solver and retrieved a laminar flow as expected. However, now I need to pass to the next step -> compressible gas simulation. I want to start as simple as possible: room temperature, long pipe (cm or even m) and pressure driven flow (ie: declare inlet pressure, outlet pressure and obtain velocity profile). I have tried sonicFoam with no success. I have started with the forward step test case. It works fine, but as soon as I change any parameter the simulation will crash. For instance if I change the temperature from 1K to 100K in the initial conditions I will get segmentation fault -> CORE dumped error.
If anyone has the slightest hint on how should I proceed and/or what solver should I tackle first for my compressible pressure driven flow simulation, feel free to answer me.
Many thanks!
mateiu2003k is offline   Reply With Quote
Old   August 24, 2016, 07:00
larmes
yeya is on a distinguished road
Hi mateiu2003k,
Im doing a similar case and i am trying it with incompressible first as well, and was wondering what did you set as your pressure difference between your inlet and outlet?
yeya is offline   Reply With Quote
compressible flow, laminar, openfoam 2.1.1, pressure driven, solvers
Inlet Boundary conditions for pressure driven flow in DSMC Jesgonse OpenFOAM Programming & Development 5 October 3, 2014 10:52
reference pressure and compressible flow bingo10 CFX 0 September 11, 2013 08:32
Cavitation in compressible flow soni7007 CFX 3 March 29, 2013 13:06
pressure BC in buoynacy driven flow Sasha FLUENT 3 October 11, 2006 11:08
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
