Strange temperature field in Laval nozzle
Old   August 14, 2014, 10:59
Default Strange temperature field in Laval nozzle
Evgeny Mogilevskiy
EvgenyMogilevskiy is on a distinguished road
I'm trying to simulate a laminar axissymnnetric flow of argon through a convergent-divergent nozzle with openFOAM. I use rhoCentralFoam solver.
BC's are the following:
inlet:
pressure timeVaryingTotalPressure
velocity pressureInletOutletVelocity
temperature totalTemperature
wall:
pressure zeroGradient
velocity 0 0 0
temperature zeroGradient
outlet
pressure, temperature waveTrassmissive
velocity zeroGradient
Sutherland transport properties are used with Pr=1.
To start the simulation, I set pressure about 1000 Pa in divergent part and 5000 Pa in convergent one. Then total pressure in the inlet starts to grow up to desired value of 50 000 Pa. Initial temperature is 300 K, total temperature at the inlet is also 300 K
I see very strange behavior of T field. First, when the inlet pressure starts to grow I see something like a shock wave with quite a big temperature (up to 400 K), but pressure goes up slowly. Then near the wall, hot boundary layer is formed. T reaches 500 K there. I tried to refine mesh in this layer to resolve temperature gradient but it seems this result is mesh-independent.
Does anyone have any suggestions?
EvgenyMogilevskiy is offline   Reply With Quote
nozzle, openfoam 2.0.x, temperature bc
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Temperature gradient for the internal Field. Philipp Dietrich OpenFOAM Programming & Development 0 July 2, 2014 04:15
Temperature field error in compressible LES aljo OpenFOAM Running, Solving & CFD 4 December 10, 2013 04:30
Help needed in configuration of laval nozzle in the windtunnel Robert2011 FLUENT 0 January 19, 2011 03:16
transient temperature field with constant velocity Törnquist CFX 0 September 16, 2003 05:22
