August 14, 2014, 09:50 |
dieselEngineFoam-O2 amount fault
Ayhan Eses
Rep Power: 17 |
Hi All,
I'm using dieselEngineFoam with FOAM extend 3.1 to simulate combustion. Simulation range is -25 +25 crank angle and simulation finished without error. i use a global reaction (N2 inert) C7H16 + 11O2 => 7CO2 + 8H2O SOI =-24 CA Injected Fuel (C7H16) mass = 12.8189 mg Mass fraction of O2 and N2 species slightly decreases after the combustion. @ -25 Total cylinder mass: 0.387525 gram (only air) mass fraction 0.234 O2 (air) | 0,09068085 gram 0.766 N2 (air) | 0,29684415 gram @ +25 Total cylinder mass: 0.400344 gram (air+fuel) [mass conservation ok] mass fraction (from species.-25.dat) C7H16 2.10186e-14 O2 0.233853 | 0,0936216454 gram N2 0.765967 | 0,3066502926 gram CO2 0.000131135 H2O 6.3041e-05 The problem is mass of O2 and N2 species increases after the combustion. i use below code to write mass fraction of species(species.-25.dat). Maybe something wrong in this code. Code:
<< runTime.value() << token::TAB << thermo.p()[0] << token::TAB << Y[0].name() << token::TAB << Y[0][0]<< token::TAB << Y[1].name() << token::TAB << Y[1][1]<< token::TAB << Y[2].name() << token::TAB << Y[2][2]<< token::TAB << Y[3].name() << token::TAB << Y[3][3]<< token::TAB << Y[4].name() << token::TAB << Y[4][4]<< token::TAB << thermo.T()[0] << token::TAB thanks in advance. log Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.1 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.1-6c0c77dee21a Exec : dieselEngineFoamtemmuz2014hrr Date : Aug 14 2014 Time : 15:29:17 Host : ayhan-virtual-machine PID : 24778 CtrlDict : /opt/foam/foam-extend-3.1/etc/controlDict Case : /home/ayhan/foam/ayhan-3.1/antorduzsilindir-foam31-multihole-enj-24-swirl-profil-20-derece-grafik-icinhrr nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create engine time --> FOAM Warning : From function IOstream::compressionEnum(const word&) in file db/IOstreams/IOstreams/IOstream.C at line 74 bad compression specifier 'off', using 'uncompressed' Create mesh for time = -25 Selecting engineMesh layered deckHeight: 0.072 piston position: 0.0639363 Reading thermophysicalProperties Selecting psiChemistryModel ODEChemistryModel<gasThermoPhysics> Selecting thermodynamics package hsPsiMixtureThermo<reactingMixture<gasThermoPhysics>> Selecting chemistryReader chemkinReader Selecting chemistrySolver ode ODEChemistryModel: Number of species = 5 and reactions = 1 Reading field U Reading/calculating face flux field phi Creating turbulence model. Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Creating field DpDt Creating field kinetic energy K Reading g Reading combustion properties Constructing Spray --> FOAM Warning : From function Cloud<ParticleType>::initCloud(const bool checkClass) in file /opt/foam/foam-extend-3.1/src/lagrangian/basic/lnInclude/CloudIO.C at line 124 Cannot read particle positions file "/home/ayhan/foam/ayhan-3.1/antorduzsilindir-foam31-multihole-enj-24-swirl-profil-20-derece-grafik-icinhrr/-25/lagrangian/defaultCloud" assuming the initial cloud contains 0 particles. Selecting injectorType multiHoleInjector injectionPressureProfile_.size() = 22, massFlowRateProfile_.size() = 22 end constructor. commonRail den alınan multihole Selecting atomizationModel off Selecting dragModel standardDragModel Selecting evaporationModel standardEvaporationModel Selecting heatTransferModel RanzMarshall Selecting wallModel reflect Selecting breakupModel ReitzKHRT Selecting collisionModel off Selecting dispersionModel off Selecting injectorModel hollowConeInjector Selecting pdfType RosinRammler Average Velocity for injector 0: 0.000127159 m/s, injection pressure = 19.9718 bar Constructing three dimensional spray injection. Courant Number mean: 0.000346976 max: 0.00280174 velocity magnitude: 5.81392 ==startSummary.H yazdiriyor... Total cylinder mass: 0.387525 gram Starting time loop Courant Number mean: 0.000346976 max: 0.00280174 velocity magnitude: 5.81392 Crank angle = -24.975 CA-deg deltaZ = 7.91565e-06 clearance: 0.00805578 Piston speed = 4.17946 m/s Piston konumu (mm)= 63.9442 Piston yerdeğiştirme (mm)= 0.00791565 Piston hızı (m/s)= 4.17946 , T = 789.788, p = 1.95045e+06, C7H16 = 0 Solving chemistry diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 UEqn.H dosyası tamam DILUPBiCG: Solving for C7H16, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for O2, Initial residual = 0.0030041, Final residual = 3.23546e-16, No Iterations 3 DILUPBiCG: Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0 YEqn.H dosyası tamam DILUPBiCG: Solving for hs, Initial residual = 0.0086605, Final residual = 2.43842e-07, No Iterations 1 EEqn.H dosyası tamam DICPCG: Solving for p, Initial residual = 0.965778, Final residual = 0.0184173, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.204614, Final residual = 0.00605899, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.00679623, Final residual = 0.000255068, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.56393e-08, global = 9.25292e-09, cumulative = 9.25292e-09 pEqn.H dosyası tamam DICPCG: Solving for p, Initial residual = 0.000641585, Final residual = 1.83956e-05, No Iterations 1 DICPCG: Solving for p, Initial residual = 1.8474e-05, Final residual = 6.7099e-07, No Iterations 1 DICPCG: Solving for p, Initial residual = 6.64488e-07, Final residual = 6.64488e-07, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.67414e-11, global = 3.58652e-11, cumulative = 9.28879e-09 pEqn.H dosyası tamam DICPCG: Solving for p, Initial residual = 1.44558e-05, Final residual = 3.33062e-07, No Iterations 1 DICPCG: Solving for p, Initial residual = 3.32992e-07, Final residual = 3.32992e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 3.32992e-07, Final residual = 3.32992e-07, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.34456e-11, global = 2.47535e-12, cumulative = 9.29126e-09 pEqn.H dosyası tamam DILUPBiCG: Solving for epsilon, Initial residual = 0.00150506, Final residual = 3.05437e-08, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.000300666, Final residual = 8.07714e-09, No Iterations 1 Mean pressure (pa): 1.95275e+06 Mean temperature (K): 815.163 Mean u'(m/s): 2.3296 Hacim (cm-küp) 46.6023 Toplam silindir kütlesi (gram): 0.387525 Number of parcels in system.... | 0 Injected liquid mass........... | 0 mg Liquid Mass in system.......... | 0 mg SMD, Dmax...................... | 0 mu, 0 mu Added gas mass................. | 2.71051e-13 mg Evaporation Continuity Error... | 2.71051e-13 mg HRRate = 0 J/s-W Heat release1 [J]: 0 sumHRRate 0 in -24.975 Heat release2 [J]: 0 ExecutionTime = 0.11 s ClockTime = 0 s ****************** ourant Number mean: 0.000315112 max: 0.00232653 velocity magnitude: 4.9143 Crank angle = 25 CA-deg deltaZ = -7.91565e-06 clearance: 0.0080637 Piston speed = -4.17946 m/s Piston konumu (mm)= 63.9363 Piston yerdeğiştirme (mm)= -0.00791565 Piston hızı (m/s)= -4.17946 , T = 733.705, p = 2.34941e+06, C7H16 = 2.10186e-14 Solving chemistry diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 UEqn.H dosyası tamam DILUPBiCG: Solving for C7H16, Initial residual = 0.000109686, Final residual = 4.94516e-16, No Iterations 2 DILUPBiCG: Solving for O2, Initial residual = 9.89698e-05, Final residual = 1.33232e-15, No Iterations 2 DILUPBiCG: Solving for CO2, Initial residual = 0.000122413, Final residual = 2.71565e-14, No Iterations 2 DILUPBiCG: Solving for H2O, Initial residual = 0.000122413, Final residual = 2.71565e-14, No Iterations 2 YEqn.H dosyası tamam DILUPBiCG: Solving for hs, Initial residual = 0.00027299, Final residual = 7.1057e-10, No Iterations 1 EEqn.H dosyası tamam DICPCG: Solving for p, Initial residual = 0.49718, Final residual = 0.018074, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.0209321, Final residual = 0.0014516, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.00145968, Final residual = 9.29612e-05, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.94866e-07, global = -2.41915e-08, cumulative = -1.4224e-05 pEqn.H dosyası tamam DICPCG: Solving for p, Initial residual = 9.84205e-05, Final residual = 6.10055e-06, No Iterations 1 DICPCG: Solving for p, Initial residual = 6.10029e-06, Final residual = 6.54184e-07, No Iterations 1 DICPCG: Solving for p, Initial residual = 6.52666e-07, Final residual = 6.52666e-07, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.36808e-09, global = -6.15307e-10, cumulative = -1.42246e-05 pEqn.H dosyası tamam DICPCG: Solving for p, Initial residual = 6.76295e-07, Final residual = 6.76295e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 6.76295e-07, Final residual = 6.76295e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 6.76295e-07, Final residual = 6.76295e-07, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.41761e-09, global = -6.15307e-10, cumulative = -1.42252e-05 pEqn.H dosyası tamam DILUPBiCG: Solving for epsilon, Initial residual = 0.00487561, Final residual = 5.09457e-09, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.0016339, Final residual = 3.83589e-09, No Iterations 1 Mean pressure (pa): 2.34247e+06 Mean temperature (K): 1095.94 Mean u'(m/s): 1.05203 Hacim (cm-küp) 46.6481 Toplam silindir kütlesi (gram): 0.400344 Number of parcels in system.... | 0 Injected liquid mass........... | 12.8189 mg Liquid Mass in system.......... | 0 mg SMD, Dmax...................... | 0 mu, 0 mu Added gas mass................. | 12.8189 mg Evaporation Continuity Error... | 1.22663e-05 mg ExecutionTime = 594.75 s ClockTime = 595 s End Last edited by ayhan515; August 14, 2014 at 09:53. Reason: species.dat file is added. |
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel | francesco | OpenFOAM Bugs | 4 | May 2, 2017 22:59 |
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example | sudo | OpenFOAM Running, Solving & CFD | 3 | April 2, 2013 18:27 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 16:06 |
How dieselEngineFoam work? | goen | OpenFOAM | 0 | July 19, 2011 10:51 |
ParaView segmentation fault only for multiphase | gwierink | OpenFOAM | 9 | March 25, 2010 08:23 |
