SimpleFoam run time comsuming
Old   August 13, 2014, 11:59
eebrah is on a distinguished road
as i perform a paralll running. I first run decomposePar (number of subdomains is defined to 8). After i run : mpi -np 8 renumberMesh -parallel. After i run : mpi -np 8 simpleFoam -parallel >log. I run to finish pyFoamPlotWatcher.py log to visualise real time residual.
eebrah is offline   Reply With Quote
Old   August 14, 2014, 03:30
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I never used renumberMesh. Did you try to start the case without that?
How many CPU cores do you have? Did you try to use just 2 ?
I recommend to start a new thread with just that "execution time / clock time" problem since I can't help you and I doubt anyone else reads this thread...
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
[solidMechanics] solidMechanics gear contact in rotation nlc OpenFOAM CC Toolkits for Fluid-Structure Interaction 3 January 11, 2015 07:41
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
