simpleFOAM auto time-step calculate?
Old   August 8, 2014, 10:11
Default simpleFOAM auto time-step calculate?
Michael Kruger
mich_K is on a distinguished road
I am trying to solve the problem of the backward facing step with simpleFOAM.
I am only interested in a steady-state solution, so time-step size is not that important.
I now I can make my mesh sufficiently small for the solution to be stable, but I want to investigate mesh independence so do not want to make changes to my mesh as it currently is.
Is there a way to make the solver automatically calculate the time-step by implementing local time-stepping or something, in order for the solution to be stable, i.e. making sure the Courant number does not go above 1?
Thank you in advance
Michael
mich_K is offline   Reply With Quote
Old   August 8, 2014, 10:40
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
You don't have any time step in simpleFoam since it is a steady-state solver. Thus, you don't have any Courant number defined.
You can only play around with the (under-)relaxation factors.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   August 8, 2014, 10:45
Michael Kruger
Ok that makes sense.
My simulation kept on crashing and I thought it was due to instability because of the mesh size, and then I decreased the relaxation factors and it worked!
Thanks
Michael
simplefoam, stability, timestep
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 14:52
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
