August 8, 2014, 08:48 |
mapFields parallel
mattia
Rep Power: 12 |
hi
If I map in serial case a consistent mesh, I don't have problems. the code that I use is: .../(source case) mapFields -sourceTime 'latestTime' -parallel ../target case -consistent If I map in parallel case I have some problems: The code for parallel case that I think to use is: .../(source case) mpirun -np 10 mapFields -sourceTime 'latestTime' -parallel ../target case -consistent is it correct? what's the syntax for mapFieldsDict of parallel case? |
mapfields, mapfieldsdict |
Running mapFields with Parallel Source and Parallel Target | RDanks | OpenFOAM Pre-Processing | 4 | August 2, 2016 05:24 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
mapFields -parallel error message | aylalisa | OpenFOAM Pre-Processing | 6 | July 9, 2014 12:19 |
The -parallel parameter of mapFields utility in OpenFOAM v2.3.0 | shuoxue | OpenFOAM Pre-Processing | 1 | April 28, 2014 05:59 |
mapFields ignores sourceTime for -parallel source | andersking | OpenFOAM Bugs | 2 | September 2, 2009 10:38 |
