Energy balance in chtMultiRegionSimpleFoam
Old   August 7, 2014, 15:28
Default Energy balance in chtMultiRegionSimpleFoam
Steffen Kuckenburg
Kucki is on a distinguished road
Hi FOAMers,
i try to simulate the heat transfer in a rectangle duct with different cooling structures but i have the problem that my energy balance in the system fails. As BC for the heating i use "compressible::turbulentHeatFluxTemperature" with a definded power and the other not couppled faces are adiabatic. But when i calculate the energy in the fluid (nearly like water) via Q_dot = m_dot*cp*(T_out-T_in) my solution ist always round about 50% too high. With a refinement of my boundary layers in the fluid mesh the solution looks a little bit better but i think my mesh is already very fine with a resolution of 0.5mm and a first cell high of about 0.05 in aspect to the resolution. The convergence of the simulation is also good and the solutions looks not wrong. As solversettings for the fluid i use the following:
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div(phi,h) bounded Gauss upwind;
div(phi,e) bounded Gauss upwind;
div(phi,Ekp) bounded Gauss upwind;
div(phi,K) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited 0.333;
interpolationSchemes
default linear;
snGradSchemes
default limited 0.333;
fluxRequired
default no;
p_rgh;
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
p_rgh
solver GAMG;
tolerance 1e-7;
relTol 0.05;
smoother DIC;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
maxIter 100;
"(U|h|e|k|omega)"
//solver PBiCG;
//preconditioner DILU;
//tolerance 1e-6;
//relTol 0.05;
solver GAMG;
tolerance 1e-7;
relTol 0.05;
smoother DILU;
mergeLevels 1;
maxIter 100;
SIMPLE
nNonOrthogonalCorrectors 2;
rhoMax rhoMax [ 1 -3 0 0 0 ] 1100;
rhoMin rhoMin [ 1 -3 0 0 0 ] 900;
relaxationFactors
fields
rho 1;
p_rgh 0.7;
equations
U 0.5;
"(h|e)" 0.99;
k 0.3;
omega 0.3;
As BC for the fluid i use:
inlet, outlet, couppledwall
U: flowRateInletVelocity, inletOutlet, fixedValue
T: fixedValue, zeroGradient, compressible::turbulentTemperatureCoupledBaffleMix ed
p_rgh: fixedFluxPressure, fixedValue, fixedFluxPressure
If sb know this problem and could help me i would be very glad.
Best regards
Steffen
Kucki is offline   Reply With Quote
Old   August 8, 2014, 06:52
Laurent Fitschy
GDTech is on a distinguished road
Energy balance can be checked using wallHeatFlux utility :
wallHeatFlux -region <region>
Thermal convergence is reached when thermal fluxes are equal on both region for any couple patch pair in your domain.
If thermal convergence is not reached, restart you computation until fluxes are balanced.
Regards,
Laurent.
GDTech is offline   Reply With Quote
Old   August 10, 2014, 12:59
Steffen Kuckenburg
Hi Laurent,
thanks for your quick reply. You are right with the wallHeatFlux utilitiy and it works. But when I say thermal convergence is reached when the wallheatflux is equal in both regions my average temperature at the outlet is much too high -.- so I think i have still a mistake in my settings. Or is there a mistake in my chain of thoughts
Best regards
Steffen
Old   August 12, 2014, 04:31
Laurent Fitschy
Would you please post your T file ?
Old   August 12, 2014, 05:45
Steffen Kuckenburg
Fluid:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 363.15;
boundaryField
    inlet
        type            fixedValue;
        value           $internalField;
    outlet
        type            zeroGradient;
    wasser_zu_alu       //coupled
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        Tnbr            T;
        kappa           fluidThermo;
        kappaName       none;
Solid:
FoamFile
    version     2.0;
    format      ascii;
    object      T;
boundaryField
    heizung        //heater
        type            compressible::turbulentHeatFluxTemperature;
        heatSource      power;        // power [W]; flux [W/m2]
        q               uniform 500;  // heat power or flux
        kappa           solidThermo; // calculate kappa=alphaEff*thermo.Cp
    kappaName    none;
        Qr              none;        // name of the radiative flux
        value           $internalField; // initial temperature value
    adiabat          //adiabatic
        type            zeroGradient;
    alu_zu_wasser         //coupled
        Tnbr            T;
        kappa           solidThermo;
        kappaName       none;
OF version is 2.3.0 and solversettings for the fluidregion are described in the first post
Old   August 12, 2014, 06:52
Laurent Fitschy
I'm not sure you are allowed to use "compressible::turbulentHeatFluxTemperature" on a solid boundary.
Would you please post the output of "wallHeatFlux -region solid" to check if this bc fixes correctly the heatFlux ?
Old   August 12, 2014, 08:33
Steffen Kuckenburg
Yes this BC works fine if I want a heatflux of 500 I get via wallHeatFlux +500 on the heater -500 from the solid to the fluid (in solid region) and +500 from the solid to the fluid (in fluid region).
Old   August 12, 2014, 08:55
Laurent Fitschy
Good !
So energy is conserved and you results are correct ;-)
Old   August 12, 2014, 11:37
Steffen Kuckenburg
yes this might be right and thanks for your support. but it doesn't solve my problem with the too high temperature at the outlet
Old   January 26, 2016, 09:23
hcl734 is on a distinguished road
Did you solved that issue?
hcl734 is offline   Reply With Quote
chtmultiregionsimplefoam, energy balance
Natural convection, problems with total energy balance MdoNascimento STAR-CCM+ 0 March 13, 2014 13:15
volumetric reaction and energy balance? m.beh FLUENT 1 October 17, 2011 18:21
Energy balance error with high prandtl numbers. David_010 OpenFOAM Running, Solving & CFD 0 January 20, 2011 06:21
Energy Balance Harshad CFX 0 March 5, 2008 07:36
HELP needed: Energy balance in gaseous combustion James Willie FLUENT 11 August 10, 2005 05:58
