August 7, 2014, 09:22 |
Floating point error due to fvschemes
harshawardhank
Rep Power: 13 |
Hello friends,
When I run simpleFOAM using LRR model I get the following warning. FOAM Warning : From function gaussConvectionScheme in file finiteVolume/convectionSchemes/gaussConvectionScheme/gaussConvectionScheme.H at line 123 Reading "/home/ict/OpenFOAM/OpenFOAM-2.3.0/case_studies/RSM_model/micro_jet_2_serial/system/fvSchemes.divSchemes.div(phi,U)" at line 33 Unbounded 'Gauss' div scheme used in steady-state solver, use 'bounded Gauss' to ensure boundedness. but when I do the necessary changes in fvSchemes It is producing SigFPE error. |
Floating point error due to fvschemes | harsha_kulkarni | OpenFOAM Running, Solving & CFD | 0 | August 7, 2014 08:28 |
Help with solving floating point exception crash. | rendagar | Main CFD Forum | 1 | March 26, 2014 07:34 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
pimpleDyMFoam constantly giving floating point exception and solution divergence | fedvasu | OpenFOAM Running, Solving & CFD | 0 | November 28, 2013 00:53 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
