very small injection point on scalar transport
Old   August 6, 2014, 04:42
Default very small injection point on scalar transport
Baek, Donghae
wes1204 is on a distinguished road
hello
I am simulating scalar transport problem in open channel.
the channel width is 3 m and water depth is 1 m.
the dye is injected near the inlet.
the problem is that the diameter of injector is too small. it is 0.001 m look like needle.
the ratio channel width and height to injector diameter is very big!!
I cannot make each cell size like this diameter (0.001 m).
Although I use snappyhex or refineMesh to make this diameter, the number of cell in domain is too many.
so I insert the injection point inside the code like below,
C[mesh.findCell (point (2.13, 22.5, 0.0575))] = 100000;
however the scalar value which I specified was diffused around point because OpenFoam use FVM method.
Is there any method to make very small injector in my case???
wes1204 is offline   Reply With Quote
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
One transport equation, two user-defined scalar, can it be solved? sharonyue FLUENT 0 April 1, 2014 23:18
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 01:37
Is it possible to influence the velocity of an scalar transport equation? jannnesss CFX 1 January 11, 2010 13:02
Unsteady kE with scalar transport - Outlet-geometry heavely effects scalar transport christian_andersen OpenFOAM 0 June 25, 2009 04:00
