Solution exploding - time step error growth drastic - mesh or pressure problem? help |
August 5, 2014, 10:03 |
Gowain
Rep Power: 12 |
Hi
I have been having this issue for quite sometime now - my solution blows up after 0.3 seconds where delta t is 0.025 seconds - it is clear as the simulation tends towards 0.3seconds the time step continuity error grows drastically - could this be a problem with the mesh: Time = 0.3 DILUPBiCG: Solving for Ux, Initial residual = 0.204415, Final residual = 5.54525e-18, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.640813, Final residual = 2.86092e-47, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.0423122, Final residual = 1.83948e-18, No Iterations 1 DILUPBiCG: Solving for T, Initial residual = 0.00825384, Final residual = 7.90288e-19, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 1.68731e-13, Final residual = 1.68731e-13, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 1.68731e-13, Final residual = 1.68731e-13, No Iterations 0 time step continuity errors : sum local = 4.47156e+27, global = 3.90964e+12, cumulative = 2.94328e+12 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? checkMesh: Mesh stats points: 549839 faces: 3109936 internal faces: 3014960 cells: 1298904 faces per cell: 4.71543 boundary patches: 9 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 929280 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 369624 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology back 1725 917 ok (non-closed singly connected) body 84480 42242 ok (closed singly connected) bottom 1719 913 ok (non-closed singly connected) front 1771 945 ok (non-closed singly connected) inlet 96 51 ok (non-closed singly connected) left 1595 855 ok (non-closed singly connected) outlet 100 53 ok (non-closed singly connected) right 1831 966 ok (non-closed singly connected) top 1659 882 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-1 -1 -1.75) (1 1 0.25) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.29639e-16 -5.51539e-17 -2.6796e-17) OK. ***High aspect ratio cells found, Max aspect ratio: 1.23469e+06, number of cells 68 <<Writing 68 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 1.00917e-10. Maximum face area = 0.0160897. Face area magnitudes OK. Min volume = 1.86084e-16. Max volume = 0.000268742. Total volume = 7.92765. Cell volumes OK. Mesh non-orthogonality Max: 89.9483 average: 28.8914 *Number of severely non-orthogonal (> 70 degrees) faces: 56830. Non-orthogonality check OK. <<Writing 56830 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 4.30872, 1 highly skew faces detected which may impair the quality of the results <<Writing 1 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 2 mesh checks. |
August 6, 2014, 05:02 |
I think it can be blamed on the mesh, both high aspect ratio and non-orthogonality would suggest some very distorted cells. Regards, Tom |
1-way time step problem in doing FSI between Fluent and Transient Structural | sihaqqi | ANSYS | 0 | November 21, 2013 03:45 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 07:00 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
