Plotting residuals
Old   August 3, 2014, 04:01
Default Plotting residuals
Marijo
krembil is on a distinguished road
How can I use the pyFoamPlotRunner.py to plot residuals with a job scheduler (bsub)?
bsub -n 60 mpirun simpleFoam -parallel
How can I redirect the output to the pyFoamPlotRunner.py and plot the residuals?
Thanks!
krembil is offline   Reply With Quote
Old   August 15, 2014, 11:41
hannes
hanness is on a distinguished road
Hi Krembil,
you can redirect the output to a logfile:
bsub -n 60 mpirun simpleFoam -parallel > log
and then use the pyFoamPlotWatcher.py to see the residuals progress.
Hannes
hanness is offline   Reply With Quote
Old   August 16, 2014, 04:38
Marijo
Thank you Hanness for the replay.
But bsub -n 60 mpirun simpleFoam -parallel > log only writes in the log the output from the bsub, not from the simpleFoam
I have found the solution:
bsub -n 60 "mpirun simpleFoam -parallel > log"
openfoam residuals
plotting grid-wise residuals defrak OpenFOAM 1 May 20, 2015 04:30
Plotting Residuals using HelyxOS EFoster2 OpenFOAM Running, Solving & CFD 0 February 17, 2014 21:05
[PyFoam] plotting residuals with different line types or points and fewer variables gustavo_nicknich OpenFOAM Community Contributions 7 March 25, 2013 07:46
Plotting Residuals ata OpenFOAM 12 July 8, 2011 03:50
Plotting residuals for solid Julie Siemens 1 October 29, 2004 07:24
