August 2, 2014, 17:54 |
Mach Range for OpenFoam Solvers
Dr. John Stutz
Hi y'all,
So I have been awarded an Army contract to do some CFD work to compare modifications on a current missile system. I will be creating drag/lift/moment curves for each variation and using them to run a 6DOF sim of the missile to determine the performance. I have used sonicFoam several times before with good results but I have not got much experience with the lower speed solvers. Can anyone give me the best solver in each Mach range? I plan on using sonicFoam down to about M=0.75. I only need the steady state turbulent solution and (I assume?) that I will be able to use the dragAndLift function for the other solvers as well? I have played around with rhoSimpleFoam but is rhoPisoFoam better? |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
How obtain a Mach number value from a case run with Xifoam solver?? | lfgmarc | OpenFOAM Programming & Development | 0 | June 15, 2011 04:00 |
non-dimensional analysis in Fluent | Endee | FLUENT | 8 | September 7, 2005 17:16 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
