Internal Flow Not Enough Turbulent - (pisoFoam, LES, sub grid models)
Old   August 1, 2014, 12:03
Question Internal Flow Not Enough Turbulent - (pisoFoam, LES, sub grid models)
vut
vut is on a distinguished road
Hi everybody,
I have a question which is tricky for months. I would be really appreciate your shares and your answers.
I want to simulate an internal flow through an injector. I use pisoFoam, LES and I tried oneEqEddy and mixed Smagorinsky sub-grid models.
The trouble I have is the flow is not at all turbulent which is the situation I waited for. Here you have my input files for mixed Smagorinsky:
In folder 0
=== p
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Inlet
type zeroGradient;
Outlet
type fixedValue;
value uniform 0;
Wall
type zeroGradient;
=== U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
Inlet
type turbulentInlet;
referenceField uniform (0 0 7.1);
fluctuationScale (0.02 0.02 0.02);
value uniform (0 0 7.1);
alpha 0.5;
Outlet
type zeroGradient;
Wall
type fixedValue;
value uniform (0 0 0);
In folder constant
=== LESProperties
LESModel mixedSmagorinsky;
delta cubeRootVol;
printCoeffs on;
mixedSmagorinskyCoeffs
filter simple;
ce 1.05;
cubeRootVolCoeffs
deltaCoeff 1;
PrandtlCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Cdelta 0.158;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Aplus 26;
Cdelta 0.158;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
=== turbulenceProperties
simulationType LESModel;
In folder system
=== fvScheme
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linear;
div((nuEff*dev(T(grad(U))))) Gauss linear;
div((dev((((surfaceSum((magSf*interpolate(sqr(U))) )|surfaceSum(magSf))-sqr((surfaceSum((magSf*interpolate(U)))|surfaceSum (magSf))))+(((0.666667)*((0.5*((surfaceSum((magSf* interpolate(magSqr(U))))|surfaceSum(magSf))-magSqr((surfaceSum((magSf*interpolate(U)))|surface Sum(magSf)))))+((((2*ck)|ce)*sqr(delta))*magSqr(de v(symm(grad(U)))))))-(nuSgs*twoSymm(grad(U))))))+(-nuEff*dev(twoSymm(grad(U)))))) Gauss linear;
// div((nu*dev(T(grad(U))))) Gauss linear;
div((grad(U)&U)) Gauss linear;
div(phi,k) Gauss limitedLinear 1;
div(phi,B) Gauss limitedLinear 1;
div(B) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
=== fvSolution
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.1;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
pFinal
$p;
smoother DICGaussSeidel;
tolerance 1e-06;
relTol 0;
"(U|k|B|nuTilda)"
solver smoothSolver;
tolerance 1e-05;
relTol 0;
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 3;
Once again, all your ideas are welcome and thank you in advance!
vut
vut is offline   Reply With Quote
Old   August 9, 2014, 15:25
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
did you find your answer? I have a same question
If you found it can you please let me know about it
Regards,
Mostafa
adambarfi is offline   Reply With Quote
Old   August 29, 2014, 03:37
vut
Dear Mostafa,
I do not have the answer for now. I hope somebody knows how to solve it.
I myself try to change some parameters to obtain a more turbulent flow inside the injector.
Without doubt, I give you further information if the problem is fixed.
Best regards,
vut
Old   August 29, 2014, 03:48
adambarfi's Avatar
Mostafa Mahmoudi
hi,
I've found the solution.
at first I defined a variable deltaT in a way that the Courant number doesn't exceed Co=0.6.
Then, I let it solve for a long time to reach a fully-developed turbulent flow (in my case, I should reach a fully-developed condition). actually the c_k and c_e which lead to C_S are very important, you should specify them in a way that the turbulent dissipation decreases and eddies formed in flow don't decay!
hope it helps you
Regards,
Mostafa
Old   August 29, 2014, 06:38
vut
Thank you, Mostafa for replying me.
Can you give more details of the way you modify C_s (or C_k and C_e)? Did you mean we can do so by reducing Ce in LESProperties file?
filter simple;
ce 1.05;
May you attach your LESProperties, fvSolution and fvSystem files?
I am not yet so confident with OpenFOAM.
Thanks in advance,
vut
Old   September 15, 2014, 15:18
Ali Shamooni
Alish1984 is on a distinguished road
Originally Posted by adambarfi View Post
hi,
hope it helps you
Regards,
Mostafa
Could you pls explain more
1. What is ur case? A channel or pipe?
2. An estimate dimension. And mesh size
3. What is ur boundary? Periodic? Or inlet, outlet and wall
4. And the most important, what do u mean by "long time"
Alish1984 is offline   Reply With Quote
Velocity curve in channel flow by pisoFoam and LES mxylondon OpenFOAM Verification & Validation 9 June 21, 2015 08:28
LES of Turbulent channel flow chivaee Main CFD Forum 6 July 21, 2012 20:38
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 02:00
Turbulent channel flow by LES Paul Main CFD Forum 14 July 6, 2009 05:02
Gas flow in vortex tube - LES and grid resolution bernarde Main CFD Forum 1 March 26, 2009 11:50
