July 25, 2014, 10:07 |
Running Propeller with PimpleDyMFoam
Rep Power: 12 |
Hi , I am quite new to openFoam and i want to simulate a wind turbine using pimpleDyMFoam . I have already worked with MRFInterFoam but I can't seem to learn how to work with pimleDyMFoam . I don't even know how to see the mesh in paraFoam .
can u suggest any tutorial or links that could help me with this case or a wind turbine . and by the way is there any other solver i can use for wind turbines ? |
September 23, 2014, 06:42 |
#2 | |
Anna Mujal
follow the Allrun.pre instructions. To see the geometry with paraFoam, once opened, use the wireframe viewing option and if you want to see carefully create a slide containing the simmetry axis. To see the results use this guide http://www.openfoam.org/version2.1.0/ami.php |
Fluent Propeller Simulation | NGH | FLUENT | 6 | May 14, 2018 00:16 |
Foam Fatal IO error when running pimpledymfoam | orkavic | OpenFOAM Running, Solving & CFD | 3 | December 18, 2013 16:05 |
[swak4Foam] Running pimpleDyMFoam with groovyBC | lexmatt | OpenFOAM Community Contributions | 2 | August 16, 2013 15:08 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
Running PimpleDyMFoam in parallel | paul b | OpenFOAM Running, Solving & CFD | 8 | April 20, 2011 05:21 |
