July 22, 2014, 19:18 |
cyclicACMI gives Courant number nan
Rep Power: 12 |
Hello all!
I am having a problem with my case, which has a interface done with the boundary condition cyclicACMI. When it starts running, Courant number has a nan value and it crashes automatically, as it is shown below: Courant Number mean: nan max: 2.732019717e-07 deltaT = 1.2e-10 Time = 1.2e-10 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 50 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 50 --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 0 the word 'nan' file: /panfs/storage/s207619/try4_dynOF/system/data.solverPerformance.p at line 0. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting I can also send the case if anyone could think you might have a clue. I have attached all the folder of the case, so if anyone can help me I would be really thankful. Cheers |
July 23, 2014, 03:14 |
Yogesh Bapat
Rep Power: 16 |
Please check weights for cyclicAMI BC. If weight is very close to zero or zero for some faces it can lead to divergence. Regards, -Yogesh |
July 23, 2014, 05:22 |
Rep Power: 12 |
I have checked and it is not the case... Here I post the full message I receive: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : pimpleFoam Date : Jul 23 2014 Time : 09:14:30 Host : "service2" PID : 152592 Case : /panfs/storage/s207619/try4_dynOF nProcs : 1 sigFpe : Floating point exception trapping - not supported on this platform fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p AMI: Creating addressing and weights between 834 source faces and 737 target faces AMI: Patch source sum(weights) min/max/average = 0.9964476021, 1, 0.9999957405 AMI: Patch target sum(weights) min/max/average = 0.985021398, 1, 0.9999796763 Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 0.00375 average: 0.00375 kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } No finite volume options present PIMPLE: max iterations = 50 field "(U|p|k|epsilon|omega)" : relTol 0, tolerance 1e-05 Starting time loop forces force1: Not including porosity effects forces force2: Not including porosity effects forces force3: Not including porosity effects forceCoeffs forceCoeffs1: Not including porosity effects forceCoeffs forceCoeffs2: Not including porosity effects forceCoeffs forceCoeffs3: Not including porosity effects forceCoeffs forceCoeffsTower: Not including porosity effects Courant Number mean: nan max: 2.732019717e-07 deltaT = 1.2e-10 Time = 1.2e-10 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 50 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 50 --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 0 the word 'nan' file: /panfs/storage/s207619/try4_dynOF/system/data.solverPerformance.p at line 0. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting Thanks! |
August 16, 2014, 12:47 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Drew1: If you haven't managed to fix this issue yet, please try upgrading to OpenFOAM 2.3.x, since a few bugs have already been solved regarding ACMI since 2.3.0 was released. Best regards, Bruno
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 13:01 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
Stable boundaries | marcoymarc | CFX | 33 | March 13, 2013 07:39 |
RMS Courant Number vs MAX Courant Number | zoozoozoo | Main CFD Forum | 3 | June 12, 2012 14:44 |
LES near wall model & courant number | kasim | CFX | 5 | March 16, 2008 19:23 |
