How to specify machine in Allrun files
Old   July 13, 2014, 23:27
Question How to specify machine in Allrun files
Zhiwei Zheng
killsecond is on a distinguished road
Hi all,
I want to run my case on a cluster, but something puzzles me.
I know that if I want to run in parallel, I need to specify the machine name in a file name "machines" and run the case with the command such as "mpirun --hostfile <machines> -np <nProcs><foamExec> <otherArgs> -parallel".
However if I want to use Allrun files to run the case, I don't know where to specify the machine name in the Allrun files. In the tutorials of OpenFOAM, I just find that the solver and core numbers are specified in the Allrun files. For example, "runParallel potentialFoam 8".
Any help will be appreciated!
killsecond is offline   Reply With Quote
Old   May 15, 2018, 14:16
Faraz
feacluster is on a distinguished road
I have the same question. How do I modify the Allrun file to specify a hostfile? I believe the line is:
runParallel $decompDict $(getApplication)
Would it be simply a matter of commenting that out and using:
mpirun $decompDict -np 18 simpleFoam -parallel
feacluster is offline   Reply With Quote
Old   May 16, 2018, 05:19
Ricky
kera is on a distinguished road
Hallo,
I am not sure if this helps, but I have discussed one such scenario in this thread.
Regards,
Ricky
If it is easy, then something is fishy!
kera is offline   Reply With Quote
Old   May 18, 2018, 16:29
Faraz
I figured it out. Basically in the Allrun file I have to replace all the runParallel lines with mpirun:
#runParallel $decompDict snappyHexMesh -overwrite
mpirun -np XX -hostfile ./machinefile snappyHexMesh -overwrite -parallel
#runParallel $decompDict patchSummary
mpirun -np XX -hostfile ./machinefile patchSummary -parallel
#runParallel $decompDict potentialFoam
mpirun -np XX -hostfile ./machinefile potentialFoam -parallel
#runParallel $decompDict $(getApplication)
mpirun -np XX -hostfile ./machinefile simpleFoam -parallel
where XX is the total number of cpus on all the machines in the machinefile.
general momentum source/hydraulic pressure jump/positive displacement machine ckleanth CFX 10 August 25, 2012 07:23
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
Monitor Files Missing Forrest FLUENT 3 March 24, 2009 17:11
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 16:01
