elbow problem
Old   July 9, 2014, 14:07
Default elbow problem
power
enginpower is on a distinguished road
Hi all,
I'm a beginner with OpenFoam and CFD.
To do experience I followed a tutorial to simulate flows in an elbow pipe.
I did different trials, setting as initial boundary conditions velocity and pressure.
If I set as inlet pressure 30MPa and as outlet pressure 2MPa and 1MPa respectively on outlet first way and on outlet second way, with command icofoam solution breaks.
That's my setting for p-file:
walls
type zeroGradient;
inlet
type fixedValue;
value uniform 30000000;
outletz+
type fixedValue;
value uniform 1000000;
outletz-
type fixedValue;
value uniform 2000000;
And this for U:
walls
type fixedValue;
value uniform (0 0 0);
inlet
type zeroGradient;
outletz+
type zeroGradient;
outletz-
type zeroGradient;
I saw that the Courant number after 1s is too big and solver fails!
How could I do to get a solution?
Also some suggestions could be useful.
Sorry if my questions is too simple for experts :-(
Thank you so much to all who wants help me!!
enginpower is offline   Reply With Quote
Old   July 9, 2014, 18:57
Wouter van der Meer
wouter is on a distinguished road
hello enginpower,
I am no expert, just reading this forum a lot. My guess is that you set three pressures inlet and two outlet, chances are that this conflicts and there is no flow that fits this. I would try two pressures an a flow and adapt the flow until the third pressure is what I want and than I can see if the third pressure is viable.
Hope this helps
Wouter
wouter is offline   Reply With Quote
Old   July 10, 2014, 03:50
matej forman
matejfor is on a distinguished road
good you are playing around to understand the code. That is how you run into more questions and you can get answers.
1) the incompressible solvers (like icoFoam) are using the relative pressure. Therefore your setting of 30 MPa is wrong by atmospheric pressure. (well it would not make much of a difference anyway)
2)seeing your pressure differences - your flow is fully compressible with such a huge differences. I do not know about your geometry and BCs, but having such a pressure difference on inlet would make a pressure wave.
3) incompressible solvers are used typically for small pressure changes. Typically you set fixedValue velocity at inlet and pressure at outlet and let the NavierStokes equations to do the rest. If you want to set the pressures at both sides, have a look at:$FOAM/tutorials/incompressible/pimpleFoam/TJunction tutorial. How to set the BCs by pressure.
4) For compressibe flows look at:$FOAM/tutorials/compressible/rhoPimpleFoam/ras/angledDuct
or $FOAM/tutorials/compressible/rhoSimplecFoam/squareBend
hope this helps
matej
matejfor is offline   Reply With Quote
Old   July 10, 2014, 11:07
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
So you have 29 and 28 MPa pressure difference in a pipe? That sounds insanely high. Are you sure you don't mean just "Pa" instead of "MPa"?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   July 11, 2014, 08:17
power
Thanks a lot to all.
I will do other trials reducing delta pressure to 1bar=0.1MPa. Then I will try matejfor's suggestions for other cases.
I will let you know if I will find other problems.
Anuway geometry I'm using is: tube T:
  • inlet way fi100 and 150 long
  • outlet ways fi200 and 300 long
I used salome to create the T. So dimension should be in m.
Is that right?
Old   July 21, 2014, 08:32
power
Hi all,
I did other trials with icoFoam.
I found that up 10Pa of delta pressure inlet/outlet flow it stops simulation maybe for some waves effect as someone suggested.
Anyway now I'm trying to do another simulation with different geometry but it fails without understanding why.
That's the log file:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.0-f5222ca19ce6
Exec   : icoFoam
Date   : Jul 19 2014
Time   : 13:12:24
Host   : "******"
PID    : 3618
Case   : /home/********
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::surfaceInterpolation::makeWeights() const at ??:?
#4  Foam::surfaceInterpolation::weights() const at ??:?
 at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
This is the p file:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    walls
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outletg
        type            fixedValue;
    value        uniform 0;
    outletp
        type            fixedValue;
        value           uniform 0;
And this is U file:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    walls
        type            fixedValue;
    inlet
        type            fixedValue;
    value        uniform (0.005 0 0);
    outletg
        type            zeroGradient;
    outletp
        type            zeroGradient;
Exactly it is not an elbow but a pipe with one inlet (the biggest one near the curve) and two outlet far from it (outletg is bigger than outletp).
The total length of the pipe is 1.5m.
I hope is it clear my problem so that you could easily help me
Thanks
Old   July 22, 2014, 08:51
power
No one could give me any suggestions?
Thank you!!
Old   July 22, 2014, 15:56
Wouter van der Meer
hello enginpower,
Did you learn from your trails? I think the problem is not so much different from the previous question you got answered. The pressure in the lowest Tee cannot be the same as in the highest outlet unless you have no flow. So a fixed value will fail.
hope this helps
Wouter
Old   July 23, 2014, 05:22
power
Hi wouter,
but I set U and not p at the inlet. There, p is zerogradient and U=0.05m/s, so not too high.
I don't understand what do you mean?
Could you suggest any value to run a possible water flow, please?
Thank you
Old   July 23, 2014, 07:47
Wouter van der Meer
hello enginpower
not the pressure at the inlet are unrealistic but the pressures at the outlets, both are the same and especially with a vertical pipe and a flow the pressures in the lower outlet is much higher than in the higher outlet.
hope this helps
Wouter
Old   July 23, 2014, 09:02
matej forman
Why don't you try the inletOtlet condition at the outlet? It lets the flow exit the domain but will block any recirculation, which improves the convergence.
here is the spec. :http://www.openfoam.org/docs/user/boundaries.php
here are some comments and disscussion: http://www.cfd-online.com/Forums/ope...onditions.html
Old   July 23, 2014, 12:53
power
Originally Posted by wouter View Post
hello enginpower
hope this helps
Wouter
Thanks a lot for your reply.
But now I don't understand something about OpenFOAM. Where could I set gravity g? What I mean is: my pipe could stay also horizontal, that is with z axis perpendicular to g vector. In that case, the natural pressure for the outlets should be equal if they go out a common space. It is what I'd want to simulate.
Sorry about my stupid issues but I'm new to this software.
@matejfor: I will try your suggestions
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 08:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
