High No Iterations in Secondary Flow Direction |
July 9, 2014, 05:11 |
Rep Power: 17 |
I am simulating a simple test case of a flat plate. The case consists of one freeslip inflow length followed by a heated no slip wall. As Solver I am using some kind of pisoFOAM with a DES turbulence model with a SA for the RANS Region. The mesh consists of 1.2 Mio cells. As I am using the DES I cannot thread the mesh as two-dimensional with the "empty" boundary condition. These walls are modelled as symmetryPlane. The wall threathment is a low Re one. The simulation is converging, but extremely slow. Examining the solver log I have seen that the max Courant Number is relatively high: ~37 and the Number of Iterations for some variables are extremely high:
But the Number of Iterations for Uy (~850) and Uz (~200) is still extremely high and the solution is slow. Are there any obvious reasons for that or some hints to fasten the solution? Thanks!
OF - 2.0.0 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 09:00 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
