July 3, 2014, 05:24 |
Problems with a barrier in a river
#1 | ||||||||
matthias
Hi;
I want to analyze a river streaming over a barrier as in the picture below I've created the "river" as one block (13,0m * 0,4m * 0,5m) and putted the barrier as .stl data in the middle of my bock. Also, I have created some inlet_patch (snappyHexMeshDict) at the beginning of my block as my water inlet: Quote:
I've tried to change the mesh in 2D, played with different verlocities and things like this, but the problem ist still the same. You can find the conent of my inter/0 folder below - maybe somebody can help me. Thanks faerber alpha.water: Quote:
July 6, 2014, 09:44 |
matthias
Here are my used mesh and inter files:
https://www.dropbox.com/s/jfondecyyttsxn0/case.zip |
July 6, 2014, 23:29 |
Matthew Denno
Rep Power: 16 |
Hi Matthias,
Controlling the water level at the outlet of the domain is something that I have had trouble with for some time. It doesn't seem that there is a universal solution available. I think the best approach depends on the specific case. Check out this thread for one solution: http://www.cfd-online.com/Forums/ope...tml#post390371 Also, although I haven't tried it yet there is a phaseHydrostaticPressure boundary condition that may work well for a fixed water level outlet...maybe used with groovyBC to specify where alpha changes from 1 to 0 (i.e. the water level).... Matt |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
[mesh manipulation] Problems with rotational cyclic boundaries | TReviol | OpenFOAM Meshing & Mesh Conversion | 8 | July 11, 2014 04:45 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 13:13 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 06:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 12:00 |
