Probe function not recording data
Old   July 1, 2014, 20:49
Default Probe function not recording data
CTR
Charles
CTR is on a distinguished road
Hello
I am trying to use the probe function in controlDict to record the solution from my solver at different points in a duct. However, when I run the solver, only the first time step is found in the post processing folder which is no good because I want to look at the flow behaviour over time. I have used probesDict as a post processing tool but I found that my data are massive and I don't really need the solutions to all other locations. Can anyone please help point me in the right direction?
Here is my controlDict file:
application mhdsolver;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 3.5;
deltaT 0.0001;
writeControl timeStep;
writeInterval 6;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
graphFormat raw;
runTimeModifiable yes;
adjustTimeStep yes;
functions
probes
type probes;
functionObjectLibs
"libsampling.so"
outputControl timeStep;
outputInterval 1;
fields
U
T
p
PotE
probeLocations
(8 0.0 0.0)
libs ("libfiniteVolume.so" "libOpenFOAM.so");
Thanks you for your time.
CTR is offline   Reply With Quote
Old   July 3, 2014, 03:35
matej forman
matejfor is on a distinguished road
well - the probe writes the data to a file which is called after the time it starts writing, therefore in that file you have values for each time in a line. In the first line you have names of variables in columns.
In your case it will look like:
time Ux Uy Uz T p PotE
for more points the set of columns would repeat to the right.
good luck
matej
matejfor is offline   Reply With Quote
Old   July 7, 2014, 20:55
CTR
Charles
Thanks for your explanation
charles
probe function
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 11:05
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 05:06
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
save data output at specific point using probe foam_noob OpenFOAM 0 March 11, 2010 03:13
