July 16, 2014, 02:57 |
#21 |
Rep Power: 13 |
Hi Thomas,
I have installed today OF 2.3. Can you upload your file again please ? This one : ************************* [EDIT] I upload the case again: https://copy.com/4HXgDQjMNCPkJHl9 ************************* I will tell you if it works fine with OF 2.3 on my computer. Thanks a lot. Regards, Mat |
July 17, 2014, 02:12 |
#22 |
zohreh imani nejad
Rep Power: 12 |
hi dear
i want to simulate a similar case but i cant download that page can you get me or uploat it again thanks |
July 17, 2014, 14:53 |
Thermal Comfort - Seated Human in a Cube Domain
#23 |
Gowain
Rep Power: 12 |
Hi
I am also looking to access the tutorial for the buoyantBoussinesqSimpleFoam solver - I believe this is solver for the case I need to run (see attached) attached is a picture of the model and domain, I have divided the boundary patches into torso, head, left arm, left forearm, left thigh, left leg and left foot (the same for the right) - in order to assign thermal boundary conditions for each in order to develop a better understanding into thermal comfort. - I am relatively new to opensoure software and would be most grateful for any pointers in the right direction - I have yet to export the case into openFoam from engrid. |
July 23, 2014, 08:52 |
#24 |
matej forman
Rep Power: 17 |
You are on the right track. I've picked the right solver.
It is hard to direct you without knowing what you want to achieve and without knowing what kind of info would be helpfull to have. Try to have some questions if you want to have answers. The more specific you are, the more precise we will be matej |
July 30, 2014, 07:26 |
BoussinesqSimpleFoam case
#25 |
Gowain
Rep Power: 12 |
Hi
My case may be similar to the one in this thread - I intend to conduct a thermal analysis on the human body within a cube domain with overhead inlet and outlet points over head - I am using the hotroom tutorial for guidance but have issues with the nut file - I receive a fatal error - I am wondering if you could share the case file for the natural ventilation with open windows to guide me - attached are images of the domain and model so you can get a feel for the problem - I eventually intend to impose heat flux boundary conditions on parts of the human body. I would be grateful for assistance - the model works in paraView and the 0 case directory seems to be fine apart from the nut file where I receive an error --FOAM FATAL ERROR: Attempt to return primitive entry IT stream....... primitiveEntry "outlet" comprises on line 60 the word 'type' on line 60 the word 'fixedValue' as a sub dictionary relatively new to openFoam and would appreciate a look at your 0 case file for natural convection case kind regards g |
July 31, 2014, 03:10 |
#26 |
Tian
Rep Power: 17 |
you should share your 0 Folder at least. So we can have a look on it. Bye Thomas
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance. |
August 4, 2014, 11:01 |
Case Files 0 folder - boussinesq aprox - solution blows up - why?
#27 |
Gowain
Rep Power: 12 |
Hi
thanks for the response attached is a link for my zero directory: https://www.dropbox.com/sh/8pqnphv42...eKloQauJkuy0ba the solution blows up after a several minutes - I can not work out what the problem could be - I would be most grateful if you could have a look - I am desperately trying to find other boussinesq examples for guidance. the case is for a human body within a cube domain with inlet and outlet points overhead. kind regards g |
October 17, 2014, 07:52 |
#28 |
Rep Power: 17 |
Hi everybody, I post here because my case is similar.
I need to roughly model a ship engine room to check the efficiency of a mechanical ventilation system. I'd like to start from a simpler case, e.g. a cubic room with an inlet and outlet hole on two different walls. Please, have you samples or tutorials for that? Thanks for your attention. |
October 17, 2014, 11:32 |
in response to Vaina74
#29 |
Gowain
Rep Power: 12 |
Hi Vaina74
I managed to successfully complete my project on thermal comfort, where I utilised Blender, enGrid and OpenFoam to evaluate thermal comfort of seated occupants within a modified cubed domain with overhead inlet and outlet to represent an enclosed cabin environment. If you like I can share a PDF file of the masters thesis where a methodology is presented - hopefully you can use it as a guide for running your own case. kind regards g |
October 17, 2014, 13:00 |
#30 |
Rep Power: 17 |
Dear Gowain, thanks for your quick reply. Good to hear about your project, I will be grateful if you would like to share your work as a starting point.
October 20, 2014, 06:11 |
Reply to Vaina74
#31 |
Gowain
Rep Power: 12 |
Vaina74 see the following link - hopefully the methodology should help you.
https://copy.com/zKBpBEzHPnGvso4u |
October 20, 2014, 08:24 |
#32 |
Rep Power: 17 |
Thanks, Gowain. I have just downloaded your thesis and at a first look it will be very useful. I will provide a feedback
October 20, 2014, 18:10 |
#33 |
Yuehan
Rep Power: 14 |
this thread seems to be very informative. thank evrrybody here.
October 21, 2014, 11:05 |
#34 |
Yuehan
Rep Power: 14 |
Hi Gowain,
where did you get 'comfortFoam' which you used in your thesis? by the way, the link Tomas provided is not valid any more. could you please share it again if you have a copy? |
April 1, 2015, 11:06 |
#35 |
behrouz
Rep Power: 11 |
hi to all
i am started linux and openfoam a few weeks ago and i am such a beginner so i try to simulate a simple ventilation case,like a simple room with 2 or 3 person in it and common load like radition and etc with one indoor supply air.wich one of case in tutorials i should use?and how can i run it? any refrence,guid or idea and... can help tnx |
June 7, 2016, 08:47 |
#36 | |
Aaron
Rep Power: 10 |
Have you solved this problem? I encountered the same problem I use foam-extend3.1 version Can you give me some suggestion? Best Regards, Aaron |
April 1, 2021, 12:22 |
BC for Single sided ventilation in a room with heat transfer - buoyantPimpleFoam
#37 | |
Olivier Dambron
Rep Power: 9 |
Hi Tian,
Would it be possible to get ahold of this case you had uploaded? I think the link is now broken. I'm working on a case of single sided ventilation in a room with heat transfer, meaning the air can come in and out from the same opening. The heat stratifies and stacks until it flows out from the top of the opening, allowing cooler air to come in from the bottom. Would you be able to recommend suitable BC for U, p, p_rgh, k, epsilon, ? i'll add radiation as with buoyantPimpleFoam once the BC are sorted. Thanks in advance, Best Olivier Quote:
April 2, 2021, 12:38 |
#38 |
Tian
Rep Power: 17 |
if you can share your 3D Model than I can try to set up an example for you. Bye Thomas
April 12, 2021, 01:34 |
I wish contact with you
#39 |
A
Rep Power: 7 |
Dear Matthieu and Dear Tian,
Firstly, I would like to say hello to you. I would like to wish you best wishes and good health in the covid-19 pandemic. Secondly, I am a newbie (OpenFOAM). Now, I am also using OpenFOAM to simulate natural ventilation on buildings. Previously, I used Fluent to simulate airflow but because of the cost of the license, I must be used OpenFOAM. So I would like to contact you, Could I contact you via email to learn about OpenFOAM and discuss it with you? Could give me your email address? Thank you so much |
Natural ventilation | tichaona | Main CFD Forum | 4 | December 9, 2011 15:34 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
Natural convection + Species in a room | Fran | FLUENT | 0 | January 29, 2009 06:21 |
Natural Ventilation Boundary conditions | lmitsc | FLUENT | 0 | October 2, 2006 13:24 |
examples of simulation on room ventilation? | lei | FLUENT | 1 | June 20, 2003 23:38 |
