Non interger scalar field power - Chemistry law
Old   June 26, 2014, 15:17
Default Non interger scalar field power - Chemistry law
Nathanael3 is on a distinguished road
Hi Foamers,
I would like to code a chemistry problem. A field named C is consumed over time following random chemistry law:
\frac{dC}{dt} = k C^{0.41}
The problem is that the exponent is not an integer.
In the case where the chemistry is:
\frac{dC}{dt} = k' C
I use the following code:
solve
fvm::ddt(C)
fvm::Sp(k, C)
It is really convenient because I solve it implicitly.
Would it be possible to do the same with the "0.41 exponent" ?
Thanks,
Nathanael.
Nathanael3 is offline   Reply With Quote
Old   June 29, 2014, 04:39
Nima Samkhaniani
nimasam is on a distinguished road
nope its not possible, you should make it linear forexample some thing like this:
solve
                                    fvm::ddt(C)
                                    fvm::Sp(k/pow(C,0.51), C)
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 29, 2014, 11:56
Hi nimasam,
Thank you for your answer. I was affraid that it would not be possible.
The problem with the suggested code is that it crashes if C = 0 somewhere in the scalarfield.
Thanks for your help,
Nathanaël.
Old   June 29, 2014, 14:12
Nima Samkhaniani
you can add a very small number forexample:
1/(pow(c,0.51)+1e-08)
chemistry
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
One-Seventh power law in turbulent pipe flows selvam2487 CFX 3 September 9, 2013 18:46
UDF power law dimsum Fluent UDF and Scheme Programming 0 June 4, 2013 03:26
Star CCM+ issue (VOF and Non newtonian power law) Sam Siemens 3 January 23, 2009 08:39
from a vecor field to get a gradient of scalar dusky.he Main CFD Forum 4 March 30, 2007 10:08
