June 26, 2014, 09:55 |
Flow in a divergent channel
Samuele Z
Rep Power: 19 |
Dear All,
I am trying to simulate the flow in a divergent channel. The geometry is attached. I fix the U at the inlet and a pressure at the outlet. I am using the k-omega model for turbulence. On the 2 sides, I am imposing cyclic BC. What happened is that I get a velocity in the z direction and the simulation never converges. Do you have any idea about how to model this? Thanks a lot, Samuele. |
June 28, 2014, 17:09 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Samuele,
So... there is no clear indication if you're simulation this with a steady-state or transient solver, nor which solver you're using. And there is no clear indication about the mesh you're using, which might possibly be the reason why you're not getting a converged solution. Therefore, based on the information you're providing, I can only deduce that you should not be using a cyclic BC on the Z direction and should instead use slip walls or symmetry patches. Best regards, Bruno
June 28, 2014, 17:34 |
Joachim Herb
Rep Power: 22 |
Could you please post your files of the 0 directory. This will it make much easier to debug your case.
July 1, 2014, 07:41 |
Samuele Z
Rep Power: 19 |
Pardon for the late reply. I am attaching the whole case.
Also, it is a stedy simulation and I am using the simpleFoam solver. Thanks a lot for any help, Samuele |
rhoCentralFoam for channel flow | fportela | OpenFOAM Running, Solving & CFD | 22 | June 10, 2014 21:14 |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 12:44 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 17:28 |
Open channel flow | motaba | Main CFD Forum | 4 | March 26, 2011 04:22 |
Flow within a thin channel | al0Vera | FLUENT | 0 | June 15, 2009 11:20 |
