Torque calculation error
Old   June 25, 2014, 19:31
Default Torque calculation error
GregM is on a distinguished road
I am hoping that someone can point me in the right direction for debugging the following issue I have run into. I may have to make a slightly simpler geometry that I can post as an example but I have not done so yet.
The particulars: OF 2.1.1. SRFSimplefoam
The duct is one of 22 (only one is modeled) that rotate at ~140RPM about a central shaft. Inlet flow velocity is specified and is axial, non-rotating. Outlet BC is zero gradient pressure.
When I calculate the torque from the change in angular momentum of the flow field I get within ~10% of the value I was expecting from a 1D analysis. When I use the libforces.so library or calculate the torque based on the pressure forces on the moving walls using paraFoam, I get a result that is about 180% of the 1D value (the parafoam value and the libforces.so value agree exactly). I would have expected that the two methods of calculating torque from the results would be closer than that to one another. Any ideas where to start debugging this problem?
thanks
GregM is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
