2.3.0 interFoam pipe flow with horizontal gravitational field
Old   June 20, 2014, 07:49
Question 2.3.0 interFoam pipe flow with horizontal gravitational field
Davide D.
dav.dap83 is on a distinguished road
Hi everyone,
I am running this case to understand how interFoam manages gravity. It consists of a horizontal pipe with Newtonian laminar flow, with a vertical gravitational field. The pipe length is chosen so that the flow is fully developed at the outlet.
You can see from the attached image that the flow at the outlet seems not to be affected by the gravity, as it depicts a typical pipe flow profile without gravity.
I cannot explain the this behaviour. Perhaps did I make something wrong at the boundary conditions?
0/p_rgh
dimensions      [1 -1 -2 0 0 0 0];
internalField   1e5;
boundaryField
    inlet
        type            fixedFluxPressure;
    outlet
        type            totalPressure;
        p0              uniform 0;
        phi             phi;
        U               U;
        rho             rho;
        psi             none;
        gamma       0;
        value           uniform $internalField;
    fixedWalls
0/U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 0.5);
    outlet
        type            zeroGradient;
    fixedWalls
        type            fixedValue;
        value           uniform (0 0 0);
Thank you in advance
dav.dap83 is offline   Reply With Quote
Old   August 9, 2014, 23:15
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
The solution is correct.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
gravity, interfoam, pipe flow
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 15:28
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
Laminar field as initial state for turbulent two phase pipe flow kjetil OpenFOAM Running, Solving & CFD 3 July 21, 2009 10:15
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
